Missing "New window"
Only a question to Bricsys-people :
Some time back in the "Window"-menu, there was a command "New Window". Sometimes this was
quite useful as you could work simultaniously on two parts of the same drawing that were wide
apart. Now this seems not to be possible anymore. Is this intended or did this command accidently
drop out or is it just me not seeing it ?
This forum was created for communication between users, if a reply from a Bricsys analyst is desired, please file a support request: support requests can be processed more efficiently, which in turn allows our analysts to reply to more questions, faster... which is probably what you want ;-)
Jörg
You need to use the VPORTS command to divide the drawing window now. Choose Viewports in the View menu to launch the command.
Thank you Louis, very nice, that's what I was after.
