Anchor Palette
Is there a way to get this in BricsCAD (as ACad has). I don't want the properties palette docked, it takes up WAY TOO MUCH screen realestate. In Acad you can anchor it to left/right, which creates a roll-over button. If the cursor moves over it the palette floats over the drawing so you can use it. When the cursor / keyboard focus leaves the palette it hides again. I can't seem to find such in BCad, maybe I'm just missing it?
I'm using Ctrl+1 shortcut to display/hide Properties palette.
I suppose that's a workaround yes. Thanks! I'd like the floating, auto-hide palette though, but for now this should suffice.
It's just that I need to create similr keyboard shortcuts for my custom palettes, I'm using OpenDCL to create these.
Thanks, I didn't know about CTRL+1. I like the sound of that floating/disappearing pallette even better, if that was possible.
