probleem met reference editing
Hallo,
Kan iemand mij helpen met het opslaan van mijn tekening. Ik krijg nu de melding "** Command QSAVE is not allowed during reference editing **, op het moment dat ik de tekening wil bewaren.
Met vriendelijke groet,
Felice
It is normal behaviour to suspend the possibility to Save while editing a block reference.
Perhaps you double clicked a block unintentionally.
Hope my english reply is ok.
Dear John,
Thanks for your answer. Can you tel me what i can co know to solve the problem?
Felice
Felice, when you "Refclose" (then save or discard) to finish editing the block, you may Save the file again.
I am often tempted to Save during Refedit, but it seems logical that I should not be able to.
There is a Ref edit Toolbar.
If you do not want to Refedit a block, avoid double clicking on it.
If you are editing a block or xref in place you can run REFCLOSE to exit. It will prompt you to save or discard the changes. Once you have exited the REFEDIT commmand you will be able to QSAVE normally again.
Hope that helps...
Oops! Ignore me :-)
