Bricscad (Linux) Beta 10.6.2
Hello All,
Bricscad (Linux) beta 10.6.2 is now available.
fixes:
- Bricscad crashed on startup with a memory exception (segmentation fault). The crash was caused by incorrect memory alignment during the initialisation of the Lisp engine. Fixed.
- Printing: allow printing to non-standard paper sizes.
known issues:
- Four toolbar docking areas exist: top, bottom, left, right. A toolbar docked in one area cannot be docked into another area by dragging. For instance, a toolbar with horizontal layout will not switch to vertical layout by dragging it to the left side. The customize dialog can be used to dock the toolbar in another area.
- In the main graphics window of Bricscad (Linux), a mouse arrow is always visible. Indeed, the display of custom mouse pointers in the main graphics window is not yet implemented on Linux. By the design of Bricscad, the lack of a mouse pointer is also a custom mouse pointer. This feature has been deliberately postponed, in favor of more important features.
- When starting Bricscad from terminal, this error message may appear: "Gdk-CRITICAL **: gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed".
- In the settings dialog, previews are not visible and the layout of the description is incorrect until the settings dialog is resized.
- The COPYCLIP window and the Bricscad Prompt History window appear as a separate application in the application bar.
- Installation issues on 64 bit. It is possible to run Bricscad (Linux) on a 64 bit system. However, the Bricscad (Linux) installers do not automatically add all required 32 bit libraries. Additional manual setup is needed.
To receive notification for subsequent versions, you can subscribe to the Bricscad for Linux RSS feed.
It is also possible to access the Bricscad for Linux RSS feed as html page.
Greetings
Tijs
This one works! I just don't File, Edit, View bar
Hi all, thank you for quick reaction
I have updated BricsCAD, it runs
But I have an issue
> bricscadv10(bricscad:29205): Gdk-CRITICAL **: gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failedbricscad: /home/build/dev/ddcad.autobuild/ddcad/src/utils/ut_print_data.cpp:625: void ut::PrintData::setPaperSize(short int, const POINT*): Assertion `!psDim || (GetPaperSize().x == psSize.x && GetPaperSize().y == psSize.y)' failed.Аварийный останов
I was trying to look at print properties dialog from layout right click
it is always repeated (i have try some times) never work
PS:
1.Tijs sorry for wrong naming you in previous post
2.please use own hash tag for linux version on twitter
#bricscad4linux for example
the same issue with print
LANG=en_EN.UTF8 bricscadv10(process:32193): Gdk-WARNING **: locale not supported by C library(process:32193): Gtk-WARNING **: Locale not supported by C library. Using the fallback 'C' locale.(bricscad:32193): Gdk-CRITICAL **: gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failedbricscad: /home/build/dev/ddcad.autobuild/ddcad/src/utils/ut_print_data.cpp:625: void ut::PrintData::setPaperSize(short int, const POINT*): Assertion `!psDim || (GetPaperSize().x == psSize.x && GetPaperSize().y == psSize.y)' failed.Аварийный останов
Quick test after installation shows the crash problem has been fixed for me (on Ubuntu UNE 10.04 32 bit running on Intel Atom D510MO motherboard).
Thanks.
@Chris Peachment can you give screenshot of a print dialog?
vs 10.6.2
vs 10.6.2
Ubuntu 10.04, 32 bit.
Occurs crash at use of the operator mtext.
saint@saint-laptop: ~ $ bricscad
(bricscad:13254): Gdk-CRITICAL **: gdk_drawable_get_depth: assertion ` GDK_IS_DRAWABLE (drawable) ' failed
Segmentation error
Segfault occurs while I use mtext or I edit the ready text.
The same was in version 10.4.12.0 -
did not confirm
Hello,
I don't know if it's a known issue, but I can't use the "copy as a block" abillity. It simply doesn't work at all.
Thanks for your works.
T.
Occurs crash at use of the operator mtext.confirm.
Segmentation error
Damned autotranslate.
Ошибка сегментации = segmentation fault
when I turn on printer - print settings dialog appears. bricscad did not crash now.
printing I will test in the morning.
Same problem as was in 10.4.12 and newer. Slow drawing with mouse cursor. With 10.4.9 is not problem.
I hawe Linux 2.6.35.4, mesa 7.8.1 with clasic DRI driver r600, glx 1.2, xdriver ati_6.13.0,
Graphic chip is Radeon RV710 rev.9555
Could you check if different values of GLSWAPMODE improve the performance? Is it the mouse cursor that is slow (e.g. when moving the mouse over the drawing while no command is active), or the whole drawing (e.g. when temporary graphics are drawn such as selection boxes)?
Thanks,
I add parameter 2 (only this parameter is working) and is better. But in 10.4.6 was more better.
And yes, problem was when I was drawing with mouse.
So i have tested printing with my epson 1160
Generally YES it prints. Now prints fine. With right plot style table and line weight.
BricsCAD now creating of a hatch is quite
1. BricsCAD become more unstable then previous build, regression here from 10.4.9 like "crash @ block creation" it was ok in 10.4.12
2. if I am create new file, and try to run print properties 100% crash
For many of you, your trial license expires tomorrow.
If your trial license is about to expire, please use the following link to ask for a new one:
http://www.bricsys.com/open/en_INTL/common/officeContact.jsp?p=298
Previously I adviced to use direct mail, but a direct mail is easily overlooked since we also receive a lot of spam by direct mail.
Regards
Tijs
Setting GLSWAPMODE=2 indeed made bricscad usable on my setup again as well.
@Andrey Didencool: Test load of existing dwg2010 file printed from model space correctly. Selection of File-Print or File-Page Setup for a new drawing caused a crash.
Sometimes File-Close with just one drawing open will cause a crash also.
@Chris Peachment
confirm, some time BC crashes when opened two drawings, and one of them (usually it new drawing, that I did not need) I close, have a crash
The operator "mtext" works randomly. Occurs segfault More often.
However, if mtext works, crash won't occur any more in this copy of the application.
Help, please.0 -
My statistic of starts bricscad.
I started it successively from the terminal and used "mtext"..
1. crash
2. work
3. work
4. work
5. crash
6. work
7. crash
8. crash
9. crash
10. crash
11. crash
12. crash
13. work
14. work
15. work
16. crash
17. crash0 -
Can print with A3 and A2 format, but have a problem. Itś like the printer can't print gray and black lines at the same time. It's not a problem of the printer because I use other software and print OK.
When I try to print a drawing all the lines that are black are well printed, but not if the drawing have some gray lines. When print grey lines, black lines are not printed.
Click on "multiline text" icon, then click two points to setup the text area. After this I expect to enter the text, but have to click again on the screen (inside the green rectangle) . I think that have a problem with the cursor capture.
Firstly,
Big thanks to the developers to spearheading a linux ACAD clone. I've been looking for something like this for many years. Additionally, I'm in the market for an ACAD-like solution for our corporate windows network since the intelliCAD codebase is horribly buggy and unstable.
On using 10.6.2 build 19557 for a few hours of my style of usage (95% command line usage/5% menus) I've compiled a few notes:
Note: I do not have the unix "focus follow mouse" active
These could be bugs, or features...
1. Focus doesnt return to command bar after picking layer/color/linetype from dropdown. I need to click in the graphics window, which starts a selection box, hit ESC, and then I have access to the command bar. I can also click directly on the command bar to get focus, but my habit is to click in the graphics window and ESC if I don't get input.
2. Focus is not on command line when opening new drawing or existing drawing. Same requiremetn as above to get focus.
3. When returing focus to application by clicking in drawing area (coming from another application), selection box is initiated instead of simply making the program the active window.4. (Elmer called this out already) Mtext focus is on settings box, not on text box. Requires clicking on text box to enter text. Additional mouse clicks.
Lastly, I'm amazed at how stable this release is. No crashes at all in 6+ hours of heavy drawing. Only lines, circles, offsets, trims, etc. though.
I have seen a transient issue that I have not been able to reproduce, and that is the ENTER command recall continually recalled MOVE regardless of the previous command entered.
All in all, I'm impressed.
Chris
Oops, forgot some relevant data...
RPM install
Fedora 12 - 32bit
Linux 2.6.32.14-127.fc12.i686.PAE #1 SMP Fri May 28 04:47:04 UTC 2010 i686 athlon i386 GNU/Linux0 -
Additionally to all the others Christopher Battles has pointed out, I can confirm this one, to me it happened with OFFSET command once, couldn't reproduce:
@Christopher Battles
1. can you create new block without crash?
2. can you get "Print settings" dialog from new drawing without crash?
I confirmed your focus issues, they are annoying.
I can consistently reproduce a crash by simply opening certain drawings.
I could reproduce the crash in several ways. Every time a stack trace of the crash showed the same situation.
I think it is the same crash Andrey Didencool and Chris Peachment experience, and other people I guess.
We are working on a fix. In the meantime, we would like to confirm or disconfirm we are talking about the same issue.
To the people that experience a crash: can you post a stack trace of the crash?
To do so, open a terminal, start bricscad in the terminal, reproduce the crash, look at the commandline output.
This is the commandline output with stack trace I get when the crash happens:
*** glibc detected *** /opt/bricsys/bricscad/v10/bricscad: free(): invalid next size (fast): 0xb01cbbd8 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6(+0x6b591)[0x3a3b591]
/lib/tls/i686/cmov/libc.so.6(+0x6cde8)[0x3a3cde8]
/lib/tls/i686/cmov/libc.so.6(cfree+0x6d)[0x3a3fecd]
/opt/bricsys/bricscad/v10/libDD_Alloc.so(odrxFree+0x1d)[0x4a0a1d]
/opt/bricsys/bricscad/v10/libDD_Alloc.so(_ZdaPv+0x21)[0x4a0ab1]
/opt/bricsys/bricscad/v10/libDD_Ge.so(_ZN8OdGeTess7Contour14breakToConvex2Ed+0x35f)[0x14bfa9f]
/opt/bricsys/bricscad/v10/libDD_Ge.so(_ZN8OdGeTess7Contour13breakToConvexEj+0xd6)[0x14bfd36]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier12shellFaceOutElPKlPK12OdGeVector3d+0x6f0)[0x5672080]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa14ExOglMetafiler12shellFaceOutElPKlPK12OdGeVector3d+0x5d)[0x239e6d]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier18generateShellFacesElPKlPK12OdGiEdgeDataPK12OdGiFaceData+0x194)[0x56737f4]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa14ExOglMetafiler18generateShellFacesElPKlPK12OdGiEdgeDataPK12OdGiFaceData+0x110)[0x23a270]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier9shellProcElPK11OdGePoint3dlPKlPK12OdGiEdgeDataPK12OdGiFaceDataPK14OdGiVertexDataPKh+0xc3)[0x5670e03]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa14ExOglMetafiler9shellProcElPK11OdGePoint3dlPKlPK12OdGiEdgeDataPK12OdGiFaceDataPK14OdGiVertexDataPKh+0x1ee)[0x23aafe]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN28OdGiConveyorEmbranchmentImpl9shellProcElPK11OdGePoint3dlPKlPK12OdGiEdgeDataPK12OdGiFaceDataPK14OdGiVertexDataPKh+0x4e)[0x5652bfe]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN13OdGiXformImpl9shellProcElPK11OdGePoint3dlPKlPK12OdGiEdgeDataPK12OdGiFaceDataPK14OdGiVertexDataPKh+0x427)[0x56fc8b7]
/opt/bricsys/bricscad/v10/libDD_DbRoot.so(_ZN14OdTrueTypeFont12outCharacterEPvP20OdGiConveyorGeometryRK16OdTextProperties+0x27c)[0x18adefc]
/opt/bricsys/bricscad/v10/libDD_DbRoot.so(_ZN16OdTrueTypeFontFT13drawCharacterEwR11OdGePoint2dP20OdGiConveyorGeometryRK16OdTextProperties+0x90)[0x18b0380]
/opt/bricsys/bricscad/v10/libDD_DbRoot.so(_ZN18OdGiDefaultContext8drawTextEP20OdGiConveyorGeometryRK11OdGePoint3dRK12OdGeVector3dS7_PKwlbPK13OdGiTextStylePS6_+0xa9c)[0x188f5ac]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa16ExGiContextForDb8drawTextEP20OdGiConveyorGeometryRK11OdGePoint3dRK12OdGeVector3dS8_PKwlbPK13OdGiTextStylePS7_+0xfd)[0x21458d]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN22OdGiGeometrySimplifier8textProcERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStylePS4_+0x1a7)[0x5671347]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN28OdGiConveyorEmbranchmentImpl8textProcERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStylePS4_+0x225)[0x56533b5]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer4textERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStyle+0x158)[0x564afa8]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN23OdGsOpenGLVectorizeView4textERK11OdGePoint3dRK12OdGeVector3dS5_PKwlbPK13OdGiTextStyle+0x8f)[0x251bbf]
/opt/bricsys/bricscad/v10/libDD_Db.so(_ZNK12OdDbTextImpl4drawER12OdGiGeometryP14OdGiCommonDrawRK8OdStringS6_bPK8OdDbText+0x3e7)[0x2ade8d7]
/opt/bricsys/bricscad/v10/libDD_Db.so(_ZNK12OdDbTextImpl5draw1ER12OdGiGeometryP14OdGiCommonDrawbPK8OdDbText+0x68)[0x2adeae8]
/opt/bricsys/bricscad/v10/libDD_Db.so(_ZNK8OdDbText9worldDrawEP13OdGiWorldDraw+0xd5)[0x2adfb95]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer6doDrawEmPK12OdGiDrawable+0x1e)[0x56480de]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN21OdGsBaseVectorizeView6doDrawEmPK12OdGiDrawable+0xb4)[0x75fe2b4]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa17BaseVectorizeView6doDrawEmPK12OdGiDrawable+0x5e)[0x1eae2e]
/opt/bricsys/bricscad/v10/libDD_Gi.so(_ZN18OdGiBaseVectorizer4drawEPK12OdGiDrawable+0x167)[0x5649037]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN14OdGsEntityNode6updateER15OdGsViewContextP17OdGsContainerNodeP16OdSiSpatialIndex+0x2ee)[0x762b07e]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN17OdGsContainerNode16safeEntityUpdateEP14OdGsEntityNodeR15OdGsViewContext+0x52)[0x761d302]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN17OdGsContainerNode14updateEntitiesER15OdGsViewContext+0x79)[0x7620169]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN17OdGsContainerNode6updateER15OdGsViewContextPS_P16OdSiSpatialIndex+0x448)[0x7620858]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN21OdGsBaseVectorizeView13updateExtentsEb+0xa26)[0x7603766]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN23OdGsBaseVectorizeDevice14updateGeometryEv+0x1b3)[0x75efce3]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN11WxOGLDevice14updateGeometryEv+0x2e)[0x2ebdae]
/opt/bricsys/bricscad/v10/libDD_Gs.so(_ZN23OdGsBaseVectorizeDevice6updateEP10OdGsDCRect+0x326)[0x75efae6]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa19BaseVectorizeDevice6updateEP10OdGsDCRect+0xab)[0x1ea86b]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN25OdGsOpenGLVectorizeDevice6updateEP10OdGsDCRect+0x5a)[0x25236a]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN22OGLBaseVectorizeDevice6updateEP10OdGsDCRect+0x11d)[0x266a8d]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN11WxOGLDevice6updateEP10OdGsDCRect+0x4a)[0x2ec29a]
/opt/bricsys/bricscad/v10/libDD_Db.so(_ZN25OdGsModelLayoutHelperImpl6updateEP10OdGsDCRect+0x5a)[0x2b5b64a]
/opt/bricsys/bricscad/v10/libodapp.so(_ZN2oa10CDwgViewer6updateENS0_11EUpdateModeEP10OdGsDCRectP4wxDC+0xd8)[0x2e3648]
/opt/bricsys/bricscad/v10/libwxgui.so(_ZN3wxg7WxgView4drawEPK12OdDbObjectIdN2oa10CDwgViewer11EUpdateModeEP4wxDC+0x3f9)[0x49c6f19]
/opt/bricsys/bricscad/v10/libwxgui.so(_ZN3wxg6WxgDoc11doRedrawAllEbP4wxDC+0x77)[0x46fb687]
/opt/bricsys/bricscad/v10/bricscad(_ZN3wxg6WxgDoc9redrawAllEb+0x21)[0x8062251]
/opt/bricsys/bricscad/v10/libwxgui.so(_ZN3wxg6WxgDoc17redrawActiveVportEb+0xb2)[0x46fb602]
/opt/bricsys/bricscad/v10/libcommands.so(_Z9cmd_regenPN2ca5CaDocE+0xa9)[0x10a8479]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca15InternalCommand7executeEP18OdEdCommandContext+0x8f)[0x8f25ff]
/opt/bricsys/bricscad/v10/libDD_Root.so(_ZN20OdEdCommandStackImpl14executeCommandEP11OdEdCommandP18OdEdCommandContext+0x1f1)[0x5ac5db1]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor11execCommandEP11OdEdCommandRbb+0x3f8)[0x8ea4c8]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor7execStrER8OdStringbP11OdEdCommandbPNS_5AliasE+0x16a)[0x8ed3aa]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor13processStringERK8OdString+0x15e)[0x8edc0e]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor18processNextCmdItemEi+0xc7)[0x8ede17]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor11processIdleEv+0x8b)[0x8edfbb]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor4mainEv+0x28)[0x8ee0a8]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor5startEv+0x63)[0x8ee1e3]
/opt/bricsys/bricscad/v10/libcadapp.so(_ZN2ca16CommandProcessor16mainWorkFlowProcEPv+0x25)[0x8ee365]
/opt/bricsys/bricscad/v10/libpth.so.20(+0x7d39)[0x30efd39]
/lib/tls/i686/cmov/libc.so.6(makecontext+0x4b)[0x3a09c5b]
/lib/libglib-2.0.so.0(g_thread_use_default_impl+0x0)[0x3e8a3d8]
======= Memory map: ========
00110000-0034c000 r-xp 00000000 08:06 2555220 /opt/bricsys/bricscad/v10/libodapp.so
0034c000-0035b000 r--p 0023b000 08:06 2555220 /opt/bricsys/bricscad/v10/libodapp.so
0035b000-0035f000 rw-p 0024a000 08:06 2555220 /opt/bricsys/bricscad/v10/libodapp.so
0035f000-00360000 rw-p 00000000 00:00 0
00360000-003a4000 r-xp 00000000 08:06 2555112 /opt/bricsys/bricscad/v10/libflyoversnap.so
003a4000-003a6000 r--p 00043000 08:06 2555112 /opt/bricsys/bricscad/v10/libflyoversnap.so
003a6000-003a7000 rw-p 00045000 08:06 2555112 /opt/bricsys/bricscad/v10/libflyoversnap.so
003a7000-003b1000 r-xp 00000000 08:06 2555247 /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
003b1000-003b2000 ---p 0000a000 08:06 2555247 /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
003b2000-003b3000 r--p 0000a000 08:06 2555247 /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
003b3000-003b4000 rw-p 0000b000 08:06 2555247 /opt/bricsys/bricscad/v10/libwx_gtk2u_gl-2.8.so.0
003b4000-003bd000 r-xp 00000000 08:06 2555143 /opt/bricsys/bricscad/v10/libwx_baseu_xml-2.8.so.0
003bd000-003be000 r--p 00008000 08:06 2555143 /opt/bricsys/bricscad/v10/libwx_baseu_xml-2.8.so.0
003be000-003bf000 rw-p 00009000 08:06 2555143 /opt/bricsys/bricscad/v10/libwx_baseu_xml-2.8.so.0
003bf000-003d2000 r-xp 00000000 08:06 595821 /lib/libz.so.1.2.3.3
003d2000-003d3000 r--p 00012000 08:06 595821 /lib/libz.so.1.2.3.3
003d3000-003d4000 rw-p 00013000 08:06 595821 /lib/libz.so.1.2.3.3
003d4000-003ef000 r-xp 00000000 08:06 1991113 /lib/ld-2.11.1.so
003ef000-003f0000 r--p 0001a000 08:06 1991113 /lib/ld-2.11.1.so
003f0000-003f1000 rw-p 0001b000 08:06 1991113 /lib/ld-2.11.1.so
003f1000-0047a000 r-xp 00000000 08:06 2555233 /opt/bricsys/bricscad/v10/libwx_gtk2u_xrc-2.8.so.0
0047a000-0047d000 r--p 00089000 08:06 2555233 /opt/bricsys/bricscad/v10/libwx_gtk2u_xrc-2.8.so.0
0047d000-0047e000 rw-p 0008c000 08:06 2555233 /opt/bricsys/bricscad/v10/libwx_gtk2u_xrc-2.8.so.0
0047e000-0047f000 rw-p 00000000 00:00 0
0047f000-0049e000 r-xp 00000000 08:06 979206 /usr/lib/libjpeg.so.62.0.0
0049e000-0049f000 r--p 0001e000 08:06 979206 /usr/lib/libjpeg.so.62.0.0
0049f000-004a0000 rw-p 0001f000 08:06 979206 /usr/lib/libjpeg.so.62.0.0
004a0000-004a1000 r-xp 00000000 08:06 2555163 /opt/bricsys/bricscad/v10/libDD_Alloc.so
004a1000-004a2000 r--p 00001000 08:06 2555163 /opt/bricsys/bricscad/v10/libDD_Alloc.so
004a2000-004a3000 rw-p 00002000 08:06 2555163 /opt/bricsys/bricscad/v10/libDD_Alloc.so
004a3000-004a5000 r-xp 00000000 08:06 2515179 /lib/tls/i686/cmov/libdl-2.11.1.so
004a5000-004a6000 r--p 00001000 08:06 2515179 /lib/tls/i686/cmov/libdl-2.11.1.so
004a6000-004a7000 rw-p 00002000 08:06 2515179 /lib/tls/i686/cmov/libdl-2.11.1.so
004a8000-004a9000 r-xp 00000000 00:00 0 [vdso]
004a9000-0065e000 r-xp 00000000 08:06 2555199 /opt/bricsys/bricscad/v10/libcmdapi.so
0065e000-00665000 r--p 001b4000 08:06 2555199 /opt/bricsys/bricscad/v10/libcmdapi.so
00665000-00668000 rw-p 001bb000 08:06 2555199 /opt/bricsys/bricscad/v10/libcmdapi.so
00668000-00669000 rw-p 00000000 00:00 0
00669000-0071c000 r-xp 00000000 08:06 2555255 /opt/bricsys/bricscad/v10/libwx_gtk2u_adv-2.8.so.0
0071c000-00724000 r--p 000b3000 08:06 2555255 /opt/bricsys/bricscad/v10/libwx_gtk2u_adv-2.8.so.0
00724000-00725000 rw-p 000bb000 08:06 2555255 /opt/bricsys/bricscad/v10/libwx_gtk2u_adv-2.8.so.0
00725000-00727000 rw-p 00000000 00:00 0
00727000-0072a000 r-xp 00000000 08:06 214484 /usr/lib/libgmodule-2.0.so.0.2400.1
0072a000-0072b000 r--p 00002000 08:06 214484 /usr/lib/libgmodule-2.0.so.0.2400.1
0072b000-0072c000 rw-p 00003000 08:06 214484 /usr/lib/libgmodule-2.0.so.0.2400.1
0072d000-007e5000 r-xp 00000000 08:06 2555120 /opt/bricsys/bricscad/v10/libutils.so
007e5000-007e6000 r--p 000b8000 08:06 2555120 /opt/bricsys/bricscad/v10/libutils.so
007e6000-007e9000 rw-p 000b9000 08:06 2555120 /opt/bricsys/bricscad/v10/libutils.so
007e9000-007eb000 rw-p 00000000 00:00 0
007eb000-00ab9000 r-xp 00000000 08:06 2555246 /opt/bricsys/bricscad/v10/libcadapp.so
00ab9000-00ac3000 r--p 002ce000 08:06 2555246 /opt/bricsys/bricscad/v10/libcadapp.so
00ac3000-00ad7000 rw-p 002d8000 08:06 2555246 /opt/bricsys/bricscad/v10/libcadapp.so
00ad7000-00adb000 rw-p 00000000 00:00 0
00adb000-00ae8000 r-xp 00000000 08:06 2555158 /opt/bricsys/bricscad/v10/libDD_SpatialIndex.so
00ae8000-00ae9000 r--p 0000c000 08:06 2555158 /opt/bricsys/bricscad/v10/libDD_SpatialIndex.so
00ae9000-00aea000 rw-p 0000d000 08:06 2555158 /opt/bricsys/bricscad/v10/libDD_SpatialIndex.so
00aea000-00aeb000 r-xp 00000000 08:06 122826 /usr/lib/nvidia-current/tls/libnvidia-tls.so.195.36.24
00aeb000-00aec000 rw-p 00000000 08:06 122826 /usr/lib/nvidia-current/tls/libnvidia-tls.so.195.36.24
00aec000-00b5e000 r-xp 00000000 08:06 2555218 /opt/bricsys/bricscad/v10/libdcl.so
00b5e000-00b61000 r--p 00071000 08:06 2555218 /opt/bricsys/bricscad/v10/libdcl.so
00b61000-00b62000 rw-p 00074000 08:06 2555218 /opt/bricsys/bricscad/v10/libdcl.so
00b62000-00b83000 rw-p 00000000 00:00 0
00b83000-00c16000 r-xp 00000000 08:06 2555105 /opt/bricsys/bricscad/v10/libwx_gtk2u_html-2.8.so.0
00c16000-00c1b000 r--p 00093000 08:06 2555105 /opt/bricsys/bricscad/v10/libwx_gtk2u_html-2.8.so.0
00c1b000-00c1d000 rw-p 00098000 08:06 2555105 /opt/bricsys/bricscad/v10/libwx_gtk2u_html-2.8.so.0
00c1d000-00c88000 r-xp 00000000 08:06 2555167 /opt/bricsys/bricscad/v10/libwx_gtk2u_aui-2.8.so.0
00c88000-00c89000 ---p 0006b000 08:06 2555167 /opt/bricsys/bricscad/v10/libwx_gtk2u_aui-2.8.so.0
00c89000-00c8c000 r--p 0006b000 08:06 2555167 /opt/bricsys/bricscad/v10/libwx_gtk2u_aui-2.8.so.0
00c8c000-00c8d000 rw-p 0006e000 08:06 2555167 /opt/bricsys/bricscad/v10/libwx_gtk2u_aui-2.8.so.0
00c8d000-00c8e000 rw-p 00000000 00:00 0
00c8e000-00cb1000 r-xp 00000000 08:06 2515288 /lib/libpng12.so.0.42.0
00cb1000-00cb2000 r--p 00022000 08:06 2515288 /lib/libpng12.so.0.42.0
00cb2000-00cb3000 rw-p 00023000 08:06 2515288 /lib/libpng12.so.0.42.0
00cb3000-00cb7000 r-xp 00000000 08:06 214485 /usr/lib/libgthread-2.0.so.0.2400.1
00cb7000-00cb8000 r--p 00003000 08:06 214485 /usr/lib/libgthread-2.0.so.0.2400.1
00cb8000-00cb9000 rw-p 00004000 08:06 214485 /usr/lib/libgthread-2.0.so.0.2400.1
00cb9000-00cbb000 r-xp 00000000 08:06 213336 /usr/lib/libXinerama.so.1.0.0
00cbb000-00cbc000 r--p 00001000 08:06 213336 /usr/lib/libXinerama.so.1.0.0
00cbc000-00cbd000 rw-p 00002000 08:06 213336 /usr/lib/libXinerama.so.1.0.0
00cbd000-00cbf000 r-xp 00000000 08:06 213750 /usr/lib/libXcomposite.so.1.0.0
00cbf000-00cc0000 r--p 00001000 08:06 213750 /usr/lib/libXcomposite.so.1.0.0
00cc0000-00cc1000 rw-p 00002000 08:06 213750 /usr/lib/libXcomposite.so.1.0.0
00cc1000-00cca000 r-xp 00000000 08:06 2555224 /opt/bricsys/bricscad/v10/libgeometry.so
00cca000-00ccb000 r--p 00008000 08:06 2555224 /opt/bricsys/bricscad/v10/libgeometry.so
00ccb000-00ccc000 rw-p 00009000 08:06 2555224 /opt/bricsys/bricscad/v10/libgeometry.so
00ccc000-01298000 r-xp 00000000 08:06 2555181 /opt/bricsys/bricscad/v10/libcommands.so
01298000-01299000 ---p 005cc000 08:06 2555181 /opt/bricsys/bricscad/v10/libcommands.so
01299000-012a8000 r--p 005cc000 08:06 2555181 /opt/bricsys/bricscad/v10/libcommands.so
012a8000-012ae000 rw-p 005db000 08:06 2555181 /opt/bricsys/bricscad/v10/libcommands.so
012ae000-012b0000 rw-p 00000000 00:00 0
012b0000-01521000 r-xp 00000000 08:06 2555201 /opt/bricsys/bricscad/v10/libDD_Ge.so
01521000-01525000 r--p 00270000 08:06 2555201 /opt/bricsys/bricscad/v10/libDD_Ge.soAborted0 -
Questions about the release:
- How do I create a configuration for my plotter? If I enter into the configuration directory of my plotter configuration created in AutoCAD, Bricscad tells me that is not usable.
- The button next to "Printer / Plotter configuration" is enabled and clickabile but if you hit the window does not open any other configuration.
- How to create custom paper sizes?
- Often when placing my design on the print size I get an "invalid input" completely senseless. This causes me capture Bricscad and its brutal off.
Now you can print (though with little difficulty as explained above) and this is a good thing:))0
