Density or mass property of solid
Is it possible to change the mass density of a solid body? or directly set the mass? The "Mass properties" tool is quite useful, but without some way of changing the mass/density of the solid, some values will always be wrong.
  • This is my problem also, I trying BC and use the 3d construction to now how much weight (kgs) the steel mechanical part... so, my drawing are in mms units and when look the mass or the volume report I must divide it by 1000,000 and multiply it by 7.85 .
    I wish a shortcut...
