Wishlist item: Print directly to PDF with plot settings in place
Hi - While we're developing the greatest CAD program in the history of the world, I'd love it if it would output directly to PDF with plot settings in place. "Export as PDF" is more-or-less useless for me and the suggested alternative PDFCreator (pseudo-printer) is a Windows program. Theoretically, a Linux user can set up a PDF printer in CUPS with CUPS-PDF, but that program has bugs in OpenSUSE 11.3, which just happens to be what I'm using. -- Nearly every Linux program I use has the ability to print directly to PDF. I hope Bricsys will be able to incorporate that feature too.
@ John; Will have, see the File menu (export and pdf export options)
Remeber that the current version is beta.
Thanks Elmer,
I see (and saw) the PDF export options on the file menu. I also see a great big warning " Note: the Export command exports drawings without applying plot settings. To create PDF files with plot settings applied, the drawing can pe printed to a PDF printer like e.g. PDFCreator which can be downloaded from http://sourceforge.net/projects/pdfcreator."
For me, it is useless to export a drawing without the plot settings. I hope Bricsys is planning a PDF export tool that does apply plot settings - possibly accessed as a built-in printer in the plotting routine - and I'm glad you say they will.
The tool PDFCreator is a Windows program.
I'm aware the program is beta and thank you for letting me review the work-in-progress.
hello
@John Hersey: You can solve this problem with
sudo apt-get install cups-pdf (or the package in you distro). Then configure a new printer (with cups or Printer options).
The new pdf printer will appear in the list of printers of briscad.Sorry english its no my native lenguage
Thanks Pablo - I know about cups-pdf, but it is buggy with the flavor of Linux I'm using (OpenSUSE,) so I was making the suggestion that Bricscad incorporate a good PDF out mechanism like most other linux based software I've used.
Your English is much better than my <insert-your-language-here.> I only speak English myself
and probably not very well.0 -
One thing I'm wondering about is the general Ubuntu print to file function, which I THINK might be working through ghostscript.
I'm not a developer, so I don't know the ins and outs of Ubuntu, and why some packages have that option and others do not. But if that could be connected to it generates very nice PDFs.
@John Hersey I managed to get cups-pdf to work well enough on openSUSE 11.2. It shouldn't be that hard to get it going on 11.3. I installed it through a repository I found on software.opensuse.org. What exactly is the problem you have?
I second to the request. Although the pdf printers do nowadays nice stuff, I really miss button which would export all layouts to PDF files (or one multipage file) at once. So instead of going through all the layouts at once, when something is changed, you could simply pick File → Exporting → Export all layouts to PDF
@ Ricardo - I have just upgraded my system from OpenSuse 11.2 64 to OpenSuse 11.3 32 (KDE 4.4.4) and have been able to load cups-pdf even though there is no official version of it in the OpenSuse repositories. (I used the 11.2 version.) Thanks for offering some assistance, but I don't seem to need it getting cups-pdf to work anymore.
@ Mattias - Thank you for the second. An unexpected hassle with cups-pdf (if you use it as I do, to keep up-to-date printable versions of all drawings) is the need to rename and move the PDF files as they are created.
@ Bradley - I don't know the ins and outs of Ubuntu printing either but I imagine it isn't much different than other GNOME flavors of Linux. Which brings me to a question for Bricscad devlelopers: have you determined if GNOME or KDE is a better environment in which to run Bricscad, if either?
for opensuse 11.3
>sudo zypper ar http://download.opensuse.org/repositories/Printing/ Printing
>sudo zypper in cups-pdf
I have installed cups-pdf, and it is generating PDF output for me.
I have one problem - I need to plot to US ARCH sheets, and I am getting non-standard sheet output. Specifically, ArchD which should be 24" x 36" is plotting as 22" x 34". This smaller sheet is an ANSI D size format, not Arch D.
Almost all my work needs to be PDF output on either the ArchD (24"x36") or Arch E1(30"x42"). The sheet sizes worked when I was running BricsCAD windows trial.
I can't determine if this is happening in BricsCAD linux or cups-pdf.
Could someone else verify this behavior for me please?
Any suggestions on resolution?
John,
I can confirm the problem with plotting to the ARCHD size sheets. I submitted a bug report to this effect last week. I received confirmation from Bricsys that they were able to reproduce this bug. Hopefully this will be fixed soon, as this is our most commonly used sheet size.
The problem I have had with cups-PDF in the past is that it will only use US-LETTER as a sheet size. The version we use seems to still have this limitation. It will generate a nice PDF, and is OK for viewing onscreen, but to print it out properly at the right scale involves a lot more work than we have time for.
Kurt Eichenberger/architect AIA
Printing to PDF is possible with CUPS-PDF. I had to edit the generic PPD file to get the sizes I wanted (takes some learning here). After that the only issue is the preview window that sometimes (but not allways) doesn't honour the landscape orientation. But the pdf prints fine, with line thickness and colors.
@Bradley, yes, I am also getting an odd sized Arch D sheet just slightly smaller than 24"x36" and the 22"x34" size you measured seems right to me although I haven't measured it myself. I also cannot determine if it's a Bricscad or Cups-pdf issue.
@Bruno, I'm getting pdf sheets with cups-pdf and they're almost useful. It's a pain to go find the pdf sheet and rename it and put it in the right directory etc., but it works in a somewhat kludgy way.
I repeat, for the Bricscad developers, that it would be nice if the program would write a pdf like nearly every other linux program - a wysiwyg print with all pen settings etc on the right size sheet in a directory you can change and with a file name you can change.
Similar problem here, we can only get the pdf output as 8.5 x 11
@B Limmer - what ppd file did you modify, it's location? I would try anything for decent pdf output.
@Tracy Helms - You can try to change the printer driver that cups-pdf uses. I had great results with the HP DesignJet 800PS driver. You can change that through the printer settings dialog.
@John Hersey: In opensuse I made a softlink to /var/spool/cups-pdf/<my-user-name> - change /var/spool according to your system (probably the same). CUPS-PDF write all PDFs there. It's very easy to use it this way.
@Tracy Helms: In opensuse the ppd is in /usr/share/cups/model/CUPS-PDF.ppd. You could change it directly or copy it with a new name, edit it and in your printer config tool (Yast>Harware>Printers in opensuse) set the CUPS-PDF printer to use this ppd. AFAIR you have to include/change the page description line in sections PageSize, PageRegion, ImageableArea and PaperDimension. For example: here are the original and edited files I'm using, where I included the landscape variations of Brazilian standards :
Original ppd:
*PPD-Adobe: "4.3"
*% "$Id: postscript.ppd,v 1.1.1.1 2000/08/24 19:23:13 goffioul Exp $"
*% Sample Postscript driver PPD file for the Common UNIX Printing
*% System (CUPS).
*% Michael Goffioul <goffioul@emic.ucl.ac.be>
*% Changes to the original file by Volker Behr, Martin-Eric Racine,
*% Nickolay Kondrashov and other contributors:
*% added IEEE-1284 device id - 2008-03-24
*% added custom page size - 2006-05-18
*% replaced page descriptions - 2006-05-18
*% InputSlot constraints removed - 2006-05-11
*% maxed out imageable regions - 2006-05-11
*% added pstitleiconv filter - 2006-05-11
*% added ledger paper size - 2006-01-29
*% match Adobe specifications - 2005-12-23
*% additional paper formats - 2005-02-03 and 2005-02-07
*% made A4 default paper size - 2005-02-03
*% Color enabled - 2003-12-02
*FormatVersion: "4.3"
*FileVersion: "1.1"
*LanguageVersion: English
*LanguageEncoding: ISOLatin1
*PCFileName: "CUPS-PDF.PPD"
*Manufacturer: "Generic"
*Product: "(CUPS v1.1)"
*ModelName: "Generic CUPS-PDF Printer"
*ShortNickName: "Generic CUPS-PDF Printer"
*NickName: "Generic CUPS-PDF Printer"
*1284DeviceID: "MFG:Generic;MDL:CUPS-PDF Printer;DES:Generic CUPS-PDF Printer;CLS:PRINTER;CMD:POSTSCRIPT;"
*% cupsFilter: "application/vnd.cups-postscript 0 pstitleiconv"
*PSVersion: "(2017.000) 0"
*LanguageLevel: "2"
*ColorDevice: True
*DefaultColorSpace: RGB
*FileSystem: False
*Throughput: "8"
*LandscapeOrientation: Plus90
*TTRasterizer: Type42
*HWMargins: 0 0 0 0
*VariablePaperSize: True
*MaxMediaWidth: 100000
*MaxMediaHeight: 100000
*NonUIOrderDependency: 100 AnySetup *CustomPageSize
*CustomPageSize True: "pop pop pop
<</PageSize [ 5 -2 roll ] /ImagingBBox null>>setpagedevice"
*End
*ParamCustomPageSize Width: 1 points 36 100000
*ParamCustomPageSize Height: 2 points 36 100000
*ParamCustomPageSize Orientation: 3 int 0 3
*ParamCustomPageSize WidthOffset: 4 points 0 0
*ParamCustomPageSize HeightOffset: 5 points 0 0
*OpenGroup: General/General
*OpenUI *PageSize/Page Size: PickOne
*OrderDependency: 100 AnySetup *PageSize
*DefaultPageSize: A4
*PageSize 11x14/11x14: "<</PageSize[792 1008]/ImagingBBox null>>setpagedevice"
*PageSize 11x17/11x17: "<</PageSize[792 1224]/ImagingBBox null>>setpagedevice"
*PageSize 13x19/13x19: "<</PageSize[936 1368]/ImagingBBox null>>setpagedevice"
*PageSize 16x20/16x20: "<</PageSize[1152 1440]/ImagingBBox null>>setpagedevice"
*PageSize 16x24/16x24: "<</PageSize[1152 1728]/ImagingBBox null>>setpagedevice"
*PageSize 2A/2A: "<</PageSize[3370 4768]/ImagingBBox null>>setpagedevice"
*PageSize 4A/4A: "<</PageSize[4768 6749]/ImagingBBox null>>setpagedevice"
*PageSize 8x10/8x10: "<</PageSize[576 720]/ImagingBBox null>>setpagedevice"
*PageSize 8x12/8x12: "<</PageSize[576 864]/ImagingBBox null>>setpagedevice"
*PageSize A0/A0: "<</PageSize[2384 3370]/ImagingBBox null>>setpagedevice"
*PageSize A1/A1: "<</PageSize[1684 2384]/ImagingBBox null>>setpagedevice"
*PageSize A2/A2: "<</PageSize[1191 1684]/ImagingBBox null>>setpagedevice"
*PageSize A3/A3: "<</PageSize[842 1191]/ImagingBBox null>>setpagedevice"
*PageSize A4/A4: "<</PageSize[595 842]/ImagingBBox null>>setpagedevice"
*PageSize A5/A5: "<</PageSize[421 595]/ImagingBBox null>>setpagedevice"
*PageSize AnsiA/ANSI A: "<</PageSize[612 792]/ImagingBBox null>>setpagedevice"
*PageSize AnsiB/ANSI B: "<</PageSize[792 1224]/ImagingBBox null>>setpagedevice"
*PageSize AnsiC/ANSI C: "<</PageSize[1224 1584]/ImagingBBox null>>setpagedevice"
*PageSize AnsiD/ANSI
"<</PageSize[1584 2448]/ImagingBBox null>>setpagedevice"
*PageSize AnsiE/ANSI E: "<</PageSize[2448 3168]/ImagingBBox null>>setpagedevice"
*PageSize ArchA/Arch A: "<</PageSize[648 864]/ImagingBBox null>>setpagedevice"
*PageSize ArchB/Arch B: "<</PageSize[864 1296]/ImagingBBox null>>setpagedevice"
*PageSize ArchC/Arch C: "<</PageSize[1296 1728]/ImagingBBox null>>setpagedevice"
*PageSize ArchD/Arch
"<</PageSize[1728 2592]/ImagingBBox null>>setpagedevice"
*PageSize ArchE/Arch E: "<</PageSize[2592 3456]/ImagingBBox null>>setpagedevice"
*PageSize C0/C0: "<</PageSize[2599 3676]/ImagingBBox null>>setpagedevice"
*PageSize C1/C1: "<</PageSize[1836 2599]/ImagingBBox null>>setpagedevice"
*PageSize C2/C2: "<</PageSize[1298 1836]/ImagingBBox null>>setpagedevice"
*PageSize C3/C3: "<</PageSize[918 1298]/ImagingBBox null>>setpagedevice"
*PageSize C4/C4: "<</PageSize[649 918]/ImagingBBox null>>setpagedevice"
*PageSize C5/C5: "<</PageSize[459 649]/ImagingBBox null>>setpagedevice"
*PageSize Env10/Envelope #10: "<</PageSize[297 684]/ImagingBBox null>>setpagedevice"
*PageSize EnvC5/Envelope C5: "<</PageSize[459 649]/ImagingBBox null>>setpagedevice"
*PageSize EnvDL/Envelope DL: "<</PageSize[312 624]/ImagingBBox null>>setpagedevice"
*PageSize EnvMonarch/Envelope Monarch: "<</PageSize[279 540]/ImagingBBox null>>setpagedevice"
*PageSize Executive/Executive: "<</PageSize[522 756]/ImagingBBox null>>setpagedevice"
*PageSize ISOB0/B0 (ISO): "<</PageSize[2834 4008]/ImagingBBox null>>setpagedevice"
*PageSize ISOB1/B1 (ISO): "<</PageSize[2004 2834]/ImagingBBox null>>setpagedevice"
*PageSize ISOB2/B2 (ISO): "<</PageSize[1417 2004]/ImagingBBox null>>setpagedevice"
*PageSize ISOB3/B3 (ISO): "<</PageSize[1000 1417]/ImagingBBox null>>setpagedevice"
*PageSize ISOB4/B4 (ISO): "<</PageSize[708 1000]/ImagingBBox null>>setpagedevice"
*PageSize ISOB5/B5 (ISO): "<</PageSize[498 708]/ImagingBBox null>>setpagedevice"
*PageSize JISB0/B0 (JIS): "<</PageSize[2919 4127]/ImagingBBox null>>setpagedevice"
*PageSize JISB1/B1 (JIS): "<</PageSize[2063 2919]/ImagingBBox null>>setpagedevice"
*PageSize JISB2/B2 (JIS): "<</PageSize[1459 2063]/ImagingBBox null>>setpagedevice"
*PageSize JISB3/B3 (JIS): "<</PageSize[1029 1459]/ImagingBBox null>>setpagedevice"
*PageSize JISB4/B4 (JIS): "<</PageSize[727 1029]/ImagingBBox null>>setpagedevice"
*PageSize JISB5/B5 (JIS): "<</PageSize[518 727]/ImagingBBox null>>setpagedevice"
*PageSize Ledger/Ledger: "<</PageSize[1224 792]/ImagingBBox null>>setpagedevice"
*PageSize Legal/US Legal: "<</PageSize[612 1008]/ImagingBBox null>>setpagedevice"
*PageSize Letter/US Letter: "<</PageSize[612 792]/ImagingBBox null>>setpagedevice"
*PageSize RA0/RA0: "<</PageSize[2437 3458]/ImagingBBox null>>setpagedevice"
*PageSize RA1/RA1: "<</PageSize[1729 2437]/ImagingBBox null>>setpagedevice"
*PageSize RA2/RA2: "<</PageSize[1218 1729]/ImagingBBox null>>setpagedevice"
*PageSize RA3/RA3: "<</PageSize[864 1218]/ImagingBBox null>>setpagedevice"
*PageSize RA4/RA4: "<</PageSize[609 864]/ImagingBBox null>>setpagedevice"
*PageSize SRA0/SRA0: "<</PageSize[2551 3628]/ImagingBBox null>>setpagedevice"
*PageSize SRA1/SRA1: "<</PageSize[1814 2551]/ImagingBBox null>>setpagedevice"
*PageSize SRA2/SRA2: "<</PageSize[1275 1814]/ImagingBBox null>>setpagedevice"
*PageSize SRA3/SRA3: "<</PageSize[907 1275]/ImagingBBox null>>setpagedevice"
*PageSize SRA4/SRA4: "<</PageSize[637 907]/ImagingBBox null>>setpagedevice"
*PageSize SuperA/Super A: "<</PageSize[644 1008]/ImagingBBox null>>setpagedevice"
*PageSize SuperB/Super B: "<</PageSize[936 1368]/ImagingBBox null>>setpagedevice"
*PageSize TabloidExtra/Tabloid Extra: "<</PageSize[864 1296]/ImagingBBox null>>setpagedevice"
*PageSize Tabloid/Tabloid: "<</PageSize[792 1224]/ImagingBBox null>>setpagedevice"
*CloseUI: *PageSize
*OpenUI *PageRegion: PickOne
*OrderDependency: 100 AnySetup *PageRegion
*DefaultPageRegion: A4
*PageRegion 11x14/11x14: "<</PageSize[792 1008]/ImagingBBox null>>setpagedevice"
*PageRegion 11x17/11x17: "<</PageSize[792 1224]/ImagingBBox null>>setpagedevice"
*PageRegion 13x19/13x19: "<</PageSize[936 1368]/ImagingBBox null>>setpagedevice"
*PageRegion 16x20/16x20: "<</PageSize[1152 1440]/ImagingBBox null>>setpagedevice"
*PageRegion 16x24/16x24: "<</PageSize[1152 1728]/ImagingBBox null>>setpagedevice"
*PageRegion 2A/2A: "<</PageSize[3370 4768]/ImagingBBox null>>setpagedevice"
*PageRegion 4A/4A: "<</PageSize[4768 6749]/ImagingBBox null>>setpagedevice"
*PageRegion 8x10/8x10: "<</PageSize[576 720]/ImagingBBox null>>setpagedevice"
*PageRegion 8x12/8x12: "<</PageSize[576 864]/ImagingBBox null>>setpagedevice"
*PageRegion A0/A0: "<</PageSize[2384 3370]/ImagingBBox null>>setpagedevice"
*PageRegion A1/A1: "<</PageSize[1684 2384]/ImagingBBox null>>setpagedevice"
*PageRegion A2/A2: "<</PageSize[1191 1684]/ImagingBBox null>>setpagedevice"
*PageRegion A3/A3: "<</PageSize[842 1191]/ImagingBBox null>>setpagedevice"
*PageRegion A4/A4: "<</PageSize[595 842]/ImagingBBox null>>setpagedevice"
*PageRegion A5/A5: "<</PageSize[421 595]/ImagingBBox null>>setpagedevice"
*PageRegion AnsiA/ANSI A: "<</PageSize[612 792]/ImagingBBox null>>setpagedevice"
*PageRegion AnsiB/ANSI B: "<</PageSize[792 1224]/ImagingBBox null>>setpagedevice"
*PageRegion AnsiC/ANSI C: "<</PageSize[1224 1584]/ImagingBBox null>>setpagedevice"
*PageRegion AnsiD/ANSI
*PageRegion AnsiE/ANSI E: "<</PageSize[2448 3168]/ImagingBBox null>>setpagedevice"
*PageRegion ArchA/Arch A: "<</PageSize[648 864]/ImagingBBox null>>setpagedevice"
*PageRegion ArchB/Arch B: "<</PageSize[864 1296]/ImagingBBox null>>setpagedevice"
*PageRegion ArchC/Arch C: "<</PageSize[1296 1728]/ImagingBBox null>>setpagedevice"
*PageRegion ArchD/Arch
*PageRegion ArchE/Arch E: "<</PageSize[2592 3456]/ImagingBBox null>>setpagedevice"
*PageRegion C0/C0: "<</PageSize[2599 3676]/ImagingBBox null>>setpagedevice"
*PageRegion C1/C1: "<</PageSize[1836 2599]/ImagingBBox null>>setpagedevice"
*PageRegion C2/C2: "<</PageSize[1298 1836]/ImagingBBox null>>setpagedevice"
*PageRegion C3/C3: "<</PageSize[918 1298]/ImagingBBox null>>setpagedevice"
*PageRegion C4/C4: "<</PageSize[649 918]/ImagingBBox null>>setpagedevice"
*PageRegion C5/C5: "<</PageSize[459 649]/ImagingBBox null>>setpagedevice"
*PageRegion Env10/Envelope #10: "<</PageSize[297 684]/ImagingBBox null>>setpagedevice"
*PageRegion EnvC5/Envelope C5: "<</PageSize[459 649]/ImagingBBox null>>setpagedevice"
*PageRegion EnvDL/Envelope DL: "<</PageSize[312 624]/ImagingBBox null>>setpagedevice"
*PageRegion EnvMonarch/Envelope Monarch: "<</PageSize[279 540]/ImagingBBox null>>setpagedevice"
*PageRegion Executive/Executive: "<</PageSize[522 756]/ImagingBBox null>>setpagedevice"
*PageRegion ISOB0/B0 (ISO): "<</PageSize[2834 4008]/ImagingBBox null>>setpagedevice"
*PageRegion ISOB1/B1 (ISO): "<</PageSize[2004 2834]/ImagingBBox null>>setpagedevice"
*PageRegion ISOB2/B2 (ISO): "<</PageSize[1417 2004]/ImagingBBox null>>setpagedevice"
*PageRegion ISOB3/B3 (ISO): "<</PageSize[1000 1417]/ImagingBBox null>>setpagedevice"
*PageRegion ISOB4/B4 (ISO): "<</PageSize[708 1000]/ImagingBBox null>>setpagedevice"
*PageRegion ISOB5/B5 (ISO): "<</PageSize[498 708]/ImagingBBox null>>setpagedevice"
*PageRegion JISB0/B0 (JIS): "<</PageSize[2919 4127]/ImagingBBox null>>setpagedevice"
*PageRegion JISB1/B1 (JIS): "<</PageSize[2063 2919]/ImagingBBox null>>setpagedevice"
*PageRegion JISB2/B2 (JIS): "<</PageSize[1459 2063]/ImagingBBox null>>setpagedevice"
*PageRegion JISB3/B3 (JIS): "<</PageSize[1029 1459]/ImagingBBox null>>setpagedevice"
*PageRegion JISB4/B4 (JIS): "<</PageSize[727 1029]/ImagingBBox null>>setpagedevice"
*PageRegion JISB5/B5 (JIS): "<</PageSize[518 727]/ImagingBBox null>>setpagedevice"
*PageRegion Ledger/Ledger: "<</PageSize[1224 792]/ImagingBBox null>>setpagedevice"
*PageRegion Legal/US Legal: "<</PageSize[612 1008]/ImagingBBox null>>setpagedevice"
*PageRegion Letter/US Letter: "<</PageSize[612 792]/ImagingBBox null>>setpagedevice"
*PageRegion RA0/RA0: "<</PageSize[2437 3458]/ImagingBBox null>>setpagedevice"
*PageRegion RA1/RA1: "<</PageSize[1729 2437]/ImagingBBox null>>setpagedevice"
*PageRegion RA2/RA2: "<</PageSize[1218 1729]/ImagingBBox null>>setpagedevice"
*PageRegion RA3/RA3: "<</PageSize[864 1218]/ImagingBBox null>>setpagedevice"
*PageRegion RA4/RA4: "<</PageSize[609 864]/ImagingBBox null>>setpagedevice"
*PageRegion SRA0/SRA0: "<</PageSize[2551 3628]/ImagingBBox null>>setpagedevice"
*PageRegion SRA1/SRA1: "<</PageSize[1814 2551]/ImagingBBox null>>setpagedevice"
*PageRegion SRA2/SRA2: "<</PageSize[1275 1814]/ImagingBBox null>>setpagedevice"
*PageRegion SRA3/SRA3: "<</PageSize[907 1275]/ImagingBBox null>>setpagedevice"
*PageRegion SRA4/SRA4: "<</PageSize[637 907]/ImagingBBox null>>setpagedevice"
*PageRegion SuperA/Super A: "<</PageSize[644 1008]/ImagingBBox null>>setpagedevice"
*PageRegion SuperB/Super B: "<</PageSize[936 1368]/ImagingBBox null>>setpagedevice"
*PageRegion TabloidExtra/Tabloid Extra: "<</PageSize[864 1296]/ImagingBBox null>>setpagedevice"
*PageRegion Tabloid/Tabloid: "<</PageSize[792 1224]/ImagingBBox null>>setpagedevice"
*CloseUI: *PageRegion
*DefaultImageableArea: A4
*ImageableArea 11x14/11x14: "0 0 792 1008"
*ImageableArea 11x17/11x17: "0 0 792 1224"
*ImageableArea 13x19/13x19: "0 0 936 1368"
*ImageableArea 16x20/16x20: "0 0 1152 1440"
*ImageableArea 16x24/16x24: "0 0 1152 1728"
*ImageableArea 2A/2A: "0 0 3370 4768"
*ImageableArea 4A/4A: "0 0 4768 6749"
*ImageableArea 8x10/8x10: "0 0 576 720"
*ImageableArea 8x12/8x12: "0 0 576 864"
*ImageableArea A0/A0: "0 0 2384 3370"
*ImageableArea A1/A1: "0 0 1684 2384"
*ImageableArea A2/A2: "0 0 1191 1684"
*ImageableArea A3/A3: "0 0 842 1191"
*ImageableArea A4/A4: "0 0 595 842"
*ImageableArea A5/A5: "0 0 421 595"
*ImageableArea AnsiA/ANSI A: "0 0 612 792"
*ImageableArea AnsiB/ANSI B: "0 0 792 1224"
*ImageableArea AnsiC/ANSI C: "0 0 1224 1584"
*ImageableArea AnsiD/ANSI
"0 0 1584 2448"
*ImageableArea AnsiE/ANSI E: "0 0 2448 3168"
*ImageableArea ArchA/Arch A: "0 0 648 864"
*ImageableArea ArchB/Arch B: "0 0 864 1296"
*ImageableArea ArchC/Arch C: "0 0 1296 1728"
*ImageableArea ArchD/Arch
"0 0 1728 2592"
*ImageableArea ArchE/Arch E: "0 0 2592 3456"
*ImageableArea C0/C0: "0 0 2599 3676"
*ImageableArea C1/C1: "0 0 1836 2599"
*ImageableArea C2/C2: "0 0 1298 1836"
*ImageableArea C3/C3: "0 0 918 1298"
*ImageableArea C4/C4: "0 0 649 918"
*ImageableArea C5/C5: "0 0 459 649"
*ImageableArea Env10/Envelope #10: "0 0 297 684"
*ImageableArea EnvC5/Envelope C5: "0 0 459 649"
*ImageableArea EnvDL/Envelope DL: "0 0 312 624"
*ImageableArea EnvMonarch/Envelope Monarch: "0 0 279 540"
*ImageableArea Executive/Executive: "0 0 522 756"
*ImageableArea ISOB0/B0 (ISO): "0 0 2834 4008"
*ImageableArea ISOB1/B1 (ISO): "0 0 2004 2834"
*ImageableArea ISOB2/B2 (ISO): "0 0 1417 2004"
*ImageableArea ISOB3/B3 (ISO): "0 0 1000 1417"
*ImageableArea ISOB4/B4 (ISO): "0 0 708 1000"
*ImageableArea ISOB5/B5 (ISO): "0 0 498 708"
*ImageableArea JISB0/B0 (JIS): "0 0 2919 4127"
*ImageableArea JISB1/B1 (JIS): "0 0 2063 2919"
*ImageableArea JISB2/B2 (JIS): "0 0 1459 2063"
*ImageableArea JISB3/B3 (JIS): "0 0 1029 1459"
*ImageableArea JISB4/B4 (JIS): "0 0 727 1029"
*ImageableArea JISB5/B5 (JIS): "0 0 518 727"
*ImageableArea Ledger/Ledger: "0 0 1224 792"
*ImageableArea Legal/US Legal: "0 0 612 1008"
*ImageableArea Letter/US Letter: "0 0 612 792"
*ImageableArea RA0/RA0: "0 0 2437 3458"
*ImageableArea RA1/RA1: "0 0 1729 2437"
*ImageableArea RA2/RA2: "0 0 1218 1729"
*ImageableArea RA3/RA3: "0 0 864 1218"
*ImageableArea RA4/RA4: "0 0 609 864"
*ImageableArea SRA0/SRA0: "0 0 2551 3628"
*ImageableArea SRA1/SRA1: "0 0 1814 2551"
*ImageableArea SRA2/SRA2: "0 0 1275 1814"
*ImageableArea SRA3/SRA3: "0 0 907 1275"
*ImageableArea SRA4/SRA4: "0 0 637 907"
*ImageableArea SuperA/Super A: "0 0 644 1008"
*ImageableArea SuperB/Super B: "0 0 936 1368"
*ImageableArea TabloidExtra/Tabloid Extra: "0 0 864 1296"
*ImageableArea Tabloid/Tabloid: "0 0 792 1224"
*DefaultPaperDimension: A4
*PaperDimension 11x14/11x14: "792 1008"
*PaperDimension 11x17/11x17: "792 1224"
*PaperDimension 13x19/13x19: "936 1368"
*PaperDimension 16x20/16x20: "1152 1440"
*PaperDimension 16x24/16x24: "1152 1728"
*PaperDimension 2A/2A: "3370 4768"
*PaperDimension 4A/4A: "4768 6749"
*PaperDimension 8x10/8x10: "576 720"
*PaperDimension 8x12/8x12: "576 864"
*PaperDimension A0/A0: "2384 3370"
*PaperDimension A1/A1: "1684 2384"
*PaperDimension A2/A2: "1191 1684"
*PaperDimension A3/A3: "842 1191"
*PaperDimension A4/A4: "595 842"
*PaperDimension A5/A5: "421 595"
*PaperDimension AnsiA/ANSI A: "612 792"
*PaperDimension AnsiB/ANSI B: "792 1224"
*PaperDimension AnsiC/ANSI C: "1224 1584"
*PaperDimension AnsiD/ANSI
"1584 2448"
*PaperDimension AnsiE/ANSI E: "2448 3168"
*PaperDimension ArchA/Arch A: "648 864"
*PaperDimension ArchB/Arch B: "864 1296"
*PaperDimension ArchC/Arch C: "1296 1728"
*PaperDimension ArchD/Arch
"1728 2592"
*PaperDimension ArchE/Arch E: "2592 3456"
*PaperDimension C0/C0: "2599 3676"
*PaperDimension C1/C1: "1836 2599"
*PaperDimension C2/C2: "1298 1836"
*PaperDimension C3/C3: "918 1298"
*PaperDimension C4/C4: "649 918"
*PaperDimension C5/C5: "459 649"
*PaperDimension Env10/Envelope #10: "297 684"
*PaperDimension EnvC5/Envelope C5: "459 649"
*PaperDimension EnvDL/Envelope DL: "312 624"
*PaperDimension EnvMonarch/Envelope Monarch: "279 540"
*PaperDimension Executive/Executive: "522 756"
*PaperDimension ISOB0/B0 (ISO): "2834 4008"
*PaperDimension ISOB1/B1 (ISO): "2004 2834"
*PaperDimension ISOB2/B2 (ISO): "1417 2004"
*PaperDimension ISOB3/B3 (ISO): "1000 1417"
*PaperDimension ISOB4/B4 (ISO): "708 1000"
*PaperDimension ISOB5/B5 (ISO): "498 708"
*PaperDimension JISB0/B0 (JIS): "2919 4127"
*PaperDimension JISB1/B1 (JIS): "2063 2919"
*PaperDimension JISB2/B2 (JIS): "1459 2063"
*PaperDimension JISB3/B3 (JIS): "1029 1459"
*PaperDimension JISB4/B4 (JIS): "727 1029"
*PaperDimension JISB5/B5 (JIS): "518 727"
*PaperDimension Ledger/Ledger: "1224 792"
*PaperDimension Legal/US Legal: "612 1008"
*PaperDimension Letter/US Letter: "612 792"
*PaperDimension RA0/RA0: "2437 3458"
*PaperDimension RA1/RA1: "1729 2437"
*PaperDimension RA2/RA2: "1218 1729"
*PaperDimension RA3/RA3: "864 1218"
*PaperDimension RA4/RA4: "609 864"
*PaperDimension SRA0/SRA0: "2551 3628"
*PaperDimension SRA1/SRA1: "1814 2551"
*PaperDimension SRA2/SRA2: "1275 1814"
*PaperDimension SRA3/SRA3: "907 1275"
*PaperDimension SRA4/SRA4: "637 907"
*PaperDimension SuperA/Super A: "644 1008"
*PaperDimension SuperB/Super B: "936 1368"
*PaperDimension TabloidExtra/Tabloid Extra: "864 1296"
*PaperDimension Tabloid/Tabloid: "792 1224"
*OpenUI *Resolution/Output Resolution: PickOne
*OrderDependency: 100 AnySetup *Resolution
*DefaultResolution: 300dpi
*Resolution 150dpi/150 DPI: "<</HWResolution[150 150]>>setpagedevice"
*Resolution 300dpi/300 DPI: "<</HWResolution[300 300]>>setpagedevice"
*Resolution 600dpi/600 DPI: "<</HWResolution[600 600]>>setpagedevice"
*Resolution 1200dpi/1200 DPI: "<</HWResolution[1200 1200]>>setpagedevice"
*Resolution 2400dpi/2400 DPI: "<</HWResolution[2400 2400]>>setpagedevice"
*CloseUI: *Resolution
*CloseGroup: General
*DefaultFont: Courier
*Font AvantGarde-Book: Standard "(001.006S)" Standard ROM
*Font AvantGarde-BookOblique: Standard "(001.006S)" Standard ROM
*Font AvantGarde-Demi: Standard "(001.007S)" Standard ROM
*Font AvantGarde-DemiOblique: Standard "(001.007S)" Standard ROM
*Font Bookman-Demi: Standard "(001.004S)" Standard ROM
*Font Bookman-DemiItalic: Standard "(001.004S)" Standard ROM
*Font Bookman-Light: Standard "(001.004S)" Standard ROM
*Font Bookman-LightItalic: Standard "(001.004S)" Standard ROM
*Font Courier: Standard "(002.004S)" Standard ROM
*Font Courier-Bold: Standard "(002.004S)" Standard ROM
*Font Courier-BoldOblique: Standard "(002.004S)" Standard ROM
*Font Courier-Oblique: Standard "(002.004S)" Standard ROM
*Font Helvetica: Standard "(001.006S)" Standard ROM
*Font Helvetica-Bold: Standard "(001.007S)" Standard ROM
*Font Helvetica-BoldOblique: Standard "(001.007S)" Standard ROM
*Font Helvetica-Narrow: Standard "(001.006S)" Standard ROM
*Font Helvetica-Narrow-Bold: Standard "(001.007S)" Standard ROM
*Font Helvetica-Narrow-BoldOblique: Standard "(001.007S)" Standard ROM
*Font Helvetica-Narrow-Oblique: Standard "(001.006S)" Standard ROM
*Font Helvetica-Oblique: Standard "(001.006S)" Standard ROM
*Font NewCenturySchlbk-Bold: Standard "(001.009S)" Standard ROM
*Font NewCenturySchlbk-BoldItalic: Standard "(001.007S)" Standard ROM
*Font NewCenturySchlbk-Italic: Standard "(001.006S)" Standard ROM
*Font NewCenturySchlbk-Roman: Standard "(001.007S)" Standard ROM
*Font Palatino-Bold: Standard "(001.005S)" Standard ROM
*Font Palatino-BoldItalic: Standard "(001.005S)" Standard ROM
*Font Palatino-Italic: Standard "(001.005S)" Standard ROM
*Font Palatino-Roman: Standard "(001.005S)" Standard ROM
*Font Symbol: Special "(001.007S)" Special ROM
*Font Times-Bold: Standard "(001.007S)" Standard ROM
*Font Times-BoldItalic: Standard "(001.009S)" Standard ROM
*Font Times-Italic: Standard "(001.007S)" Standard ROM
*Font Times-Roman: Standard "(001.007S)" Standard ROM
*Font ZapfChancery-MediumItalic: Standard "(001.007S)" Standard ROM
*Font ZapfDingbats: Special "(001.004S)" Standard ROM
*% End of "$Id: postscript.ppd,v 1.1.1.1 2000/08/24 19:23:13 goffioul Exp $".
Edited ppd:
*PPD-Adobe: "4.3"
*% System (CUPS).
*FileVersion: "1.1"
*LanguageLevel: "2"
*ColorDevice: True
*FileSystem: False
*Throughput: "8"
*HWMargins: 0 0 0 0
*End
*PageSize A0L/A0L: "<</PageSize[3370 2384]/ImagingBBox null>>setpagedevice"
*PageSize A1L/A1L: "<</PageSize[2384 1684]/ImagingBBox null>>setpagedevice"
*CloseUI: *PageSize
*PageRegion A0L/A0L: "<</PageSize[3370 2384]/ImagingBBox null>>setpagedevice"
*PageRegion A1L/A1L: "<</PageSize[2384 1684]/ImagingBBox null>>setpagedevice"
*ImageableArea A0L/A0L: "0 0 3370 2384"
*ImageableArea A1L/A1L: "0 0 2384 1684"
"0 0 1584 2448"
"0 0 1728 2592"
*PaperDimension A0L/A0L: "3370 2384"
*PaperDimension A1L/A1L: "2384 1684"
"1584 2448"
"1728 2592"
@ Bruno - yes, I've done the same thing. It's an inadequate solution IMHO. My purpose in writing PDFs is to keep record copies of my drawings, ready to print to paper at any time. The extra step of renaming each file from the spool directory to one for the project shouldn't be necessary and if I did want to make a script to batch print my drawings, I'd need to drop out of Bricscad between each print and issue a bash mv command (I keep several drawings within a single DWG file and since I'm unable to control the file name of the outputted PDF from within Bricscad each subsequent print would overwrite the previous) and although probably do-able, I don't want to spend the time to learn how to write a script that incorporates bash commands.
@Hersey: from the cups-pdf readme file:
"Once you print to the new device the output directory selected in
cups-pdf.conf (defaults to /var/spool/cups-pdf) will be created and all
converted PDF files will be placed in subdirectories named after the owner
of the print job. In case the owner cannot be identified (i.e. does not
exist on the server) the output is placed in the directory for anonymous
operation (if not disabled in cups-pdf.conf - defaults to
/var/spool/cups-pdf/ANONYMOUS/).
Furthermore if logging is enabled the logfile will be placed by default in
/var/log/cups."When I print a file from bricscad to PDF, say, file DRAWING1.dwg, I get a file named Bricscad-DRAWING1-Model.pdf in /var/spool/cups-pdf/<my-user-name>.
If I immediately print another file, say, DRAWING57.dwg, I get, guess what: Bricscad-DRAWING57-Model.pdf. No repeated name, no overwriting, no problems with batch printing.
So I'd suggest you check if you are printing as your regular user, not ANONYMOUS, and if your regular user has write permissions to /var/spool/cups-pdf/<your-regular-user-name>.
Note that I'm running Bricscad in opensuse 11.1 x86_64, with cups-pdf version 2.5.0. Your distro may have different paths/version.
Bruno, I repeat, I keep several drawings within a single DWG file. Each sheet printed from the same file is given the same name. Yes, I could work around it by setting up different layouts for different sheets, but that would require I change the way I work and I'm not interested in investing the hundreds of hours it would take me to change all my projects that have already been formatted.
Ah, I tought your problem was different. Sorry you had to repeat yourself.
I'm curious: how do you batch-print several drawings from one file with different names in AutoCAD (or whatever CAD you're using)? I didn't think that was possible.
John Hersey,
This can be done: Cups-pdf can be set to postprocess and scripts can be installed to pop up a window for selection of the destination and the filename. The best directions I have found are at: http://ubuntuforums.org/showthread.php?t=837257 See post #2 by mexlinux and his follow-up not in post #5.
The poster provides a shell script, a .py script and an .xml script. Modifications, as root, are required to an apparmor file and to the cups-pdf configuration file
I have gone through the steps and it does work, but there are some caveats: first, some of his pop-choices are in Spanish (no big thing to a non-Spanish speaker, as they are still understandable) second, the CUPS configurations are not all editable from Bricscad (for instance, if you set to ANSI-D size elsewhere, no setting available in Bricscad will over-ride that to, say, letter size).
GTKLP is a program that lets you edit all the options (but not file name or destination), but it is not callable from within Bricscad; it is called from the command line... so, not too useful.
All-in-all, this is cumbersome and not very smooth. It would be far better if Bricscad simply had a "Print To File" option button available no matter what printer a user had selected. Like you, I prefer to print to .pdf both as a record file and to distribute drawing files to other users in non-modifiable form.
I realized after reviewing some of the earlier posts in this thread that using GTKLP can fix the problem that many have had with incorrect sheet sizes of .pdf prints. The problem is that the Bricscad print dialog does not access all the printer options (it should, but it does not. This is a bug).
GTKLP is available in the Ubuntu repository (I'm using Ubuntu) and typing GTKLP in the terminal calls the program. It lets you set many print options. Once set there, those options seem to remain valid when you next use the printer from Bricscad. (Of course, it is a GTK app... which goes with Gnome. However, I understand there is a 'kprinter' equivalent in KDE desktops).
This has turned into a discussion of how to make cups-pdf work, which is precisely what I didn't want to get into when I suggested that Bricscad incorporate a proper print-to-PDF option in the print dialogue. I suppose the discussion can serve as an example of why print-to-pdf has to be incoprporated into the program.
@S Schuller - thank you for the cups-pdf script idea. I might need to pursue it if time allows.
@Bruno Limmer - I gave the batch printing problem as an example of the hoops we need to jump through because the print-to-PDF option isn't available (yet,) but a script could be written that could say something like:
print 0,0 36,24 ...
print 0,24 36,48 ...
print 0,48 48,72 ...
where the coordinates represent the corners of 3 sheet stacked horizontally (for example) in paper space and "..." represents the balance of the input necessary for the print command. I realize it's simplistic, but it could work. It would be a script, not a program. I suppose that such a script could be created for every DWG file and then another script could be written that would open DWG after DWG and execute the scripts associated with each DWG. -- OK, I just tested my script suggestion and I see there's no way to generate a plot completely from the command line. Last time I wrote scripts for plot generation, there was. That was ages ago though, with AutoCAD on Sparc Sun (unix) stations. -- I give up.
" Last time I wrote scripts for plot generation, there was. That was ages ago though..."
I used to do a thing like that, too. All my plot windows were set up in a grid and I had a square on a tablet to click to plot each one. Slick, smooth and long in the past.
I'm new to Bricscad, and I am running Version 10.6.5 Build 18704 under Debian kernel 2.6.30-2-amd64.
When I try to "export to pdf" all I get is "Unable to Export the file."
I take it from this discussion that Linux Bricscad has no native PDF generation support at this point? Or am I missing something else? A PDF library perhaps?
I am not interested in implementing CUPS as it screws up my lprng setup, which works fine across the multiple FBSD & Linux systems in my workspace. It also sounds a bit like the tail wagging the dog.
As an aside, I noticed no ability to export to SVG, which seems almost a no-brainer. Is there any interest in the community for this?
@Andrew Ghali - You're not missing anything. Bricscad is! It still doesn't have PDF export capabilities. In fact it can't export to anything. So far the only solution users have to get files out of it (apart from the dwg and dxf formats) is really just cups-pdf. Isn't there some kind of PDF or EPS backend for lprng?
