Hello,
Is it possible, when you have colored an area for example, to make the color transparent?
In fact, I'd like to see across the color but I don' want hatches.
I hope that someone may help me .
Thanks a lot
  • It depends from what you mean by "colored area". If it is an image you can indeed switch transparency on : menu -> images -> image trasnparency.
    If it is a solid or a hatch, to my knowledge, you can't make them transparent, what you can do is to use draworder to send them to the back of the drawing,
    so that item, that before, were covered by the hatch/solid now appear above it : menu -> tools -> draworder -> send to back.
    You can use the settings dialogue ( -> settings -> drafting -> hatches ) and set it to" set behind boundary" or" send to back" so you've got it right straight away.
