Using Bricscad as a .dwg -Viewer only?
Is there a way using Bricscad (Pro) as a dwg viewer (disabling the possibility to save changes in a drawing)?
I need to check this, but i think when you install V7 on the same machine with licensed V10, v7 turns read only.
on V10 maybe you can write a routine or script that performs something like this each time Bricscad is launched:
undefine _save
undefine _qsave
undefine _saveas
undefine _export
undefine _copyclip
undefine _copybase
udefine _cutclip
undefine redefine0
