underline dimension text
How to underline dimensiontext. In Acad you can underline dimensiontext with %%u, but in BC it does not work. Is there an other way to do so??
Regards.
Peter
Try:
Prefix: {\L
Suffix: }(I've looked at Mtext formatting for underlined text and this seems to work)
It works, but it is a time-consuming process in coparision with %%u.
Thanks.
Peter
I would advise you to create a separate dimstyle with this pre- and suffix. Using this dimstyle and the properties bar, underlining one or more dimensions will take just 4 clicks.
Typing \L in the Dim Prefix field is sufficient to underline the dimension text.
Typing \L is the solution.
Thanks and regards.
Peter
