BricsCAD v10 for Linux test in ubuntu 10.04
I'm a AutoCAD user over 10 years , and using linux for fun...
When i found that BricsCAD release a native linux vsetion ,i downloaded and installed in my ubuntu 10.04 system (locale :uft-8_zhCN).
1.As a Chinese , this version (v10) can't support Chinese SHX fonts .
in my test , i select a >=2007 dwg and a <=2006 dwg, the results is :
<= 2006 (Text encoding as OS locale) : shx_text_in_drawing_display : OK shx_text_in_editbox_ (and layer name list): looks like "\M+xxxx..." , can't read.
ttf_text_in_drawing_display : display in Korea Chars , not Chinese. ttf_text_in_editbox_ (and layer name list): "\M+xxxx..."
>=2007 (unicode Text storage) : shx_text_in_drawing_display : looks like "????????" shx_text_in_editbox_ (and layer name list): OK
ttf_text_in_drawing_display : OK ttf_text_in_editbox_ (and layer name list): OK
2. input "(arx)" , crashed....
3. Osnap can't "Magnet"
4. Mouse focus only in Drawing region and command window then user can input...
5. When start inplace refedit, the RefEdit toolbar can't display automaticly...
6. Use Ctrl+Shift+V (paste as block" , no reponse and not work at all.
7. No Bedit
8. Wish Tabbar (opening drawing file tabbar) can drag for re_position and can select order type , if right click it ,can display some drawing properties (like idwgtab for AutoCAD)
9. Wish support Thumb preview for dwg files in file manager (Nautilus or Dolphin)
10. when cross rectangle select objects , mouse move made a shadow region so user can't see any objects in the region. the reson maybe is my ATI videocard (not installed ATI offical driver)
3. Object snap works for me.
4. Yes, focus is not full developed
6. Yes, don't work
9. Wish too, at least wish the bricscad icon
10. Not for me, works fine with nvidia
Wish : add Annotative property.
