Issue with libraries: libcairo.so.2 after upgrade system
I have big issue with libcairo.so.2
Bricscad not start after my system upgrade (Debian AMD64)
According to this bug http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=596437
I manually installed ia32-libs-gtk after change break line in /var/lib/dpkg/status
After start (from terminal) system show:
# bricscadv10
/opt/bricsys/bricscad/v10/bricscad: error while loading shared libraries: libcairo.so.2: cannot open shared object file: No such file or directory
Maybe some symbolic link is broken?
# dpkg -l | grep libcairo
ii libcairo-perl 1.070-1 Perl interface to the Cairo graphics library
ii libcairo2 1.8.10-5 The Cairo 2D vector graphics library
ii libcairo5c-0 1.4 nickle bindings for the cairo graphics library
ii libcairomm-1.0-1 1.8.4-3 C++ wrappers for Cairo (shared libraries)
#uname -r
2.6.32-5-amd64
# ls | grep libcairo
libcairo-5c.so.0
libcairo-5c.so.0.0.0
libcairomm-1.0.so.1
libcairomm-1.0.so.1.4.0
libcairo.so.2
libcairo.so.2.10800.10
dpkg -l | grep 32
ii firmware-linux-free 2.6.32-21 Binary firmware for various drivers in the Linux kernel
ii ia32-crossover-standard 9.0.1-1 Run Windows applications like MS Office
ii ia32-libs 20100908 ia32 shared libraries for use on amd64 and ia64 systems
ii ia32-libs-gtk 20090804 GTK+ ia32 shared libraries
ii lib32asound2 1.0.23-1 shared library for ALSA applications (32 bit)
ii lib32gcc1 1:4.4.4-14 GCC support library (32 bit Version)
rc lib32ncurses5 5.7+20100313-3 shared libraries for terminal handling (32-bit)
ii lib32nss-mdns 0.10-3.1 NSS module for Multicast DNS name resolution (32-bits version)
ii lib32stdc++6 4.4.4-14 The GNU Standard C++ Library v3 (32 bit Version)
ii lib32v4l-0 0.8.0-1 Collection of video4linux support libraries (32 bits)
ii lib32z1 1:1.2.3.4.dfsg-3 compression library - 32 bit runtime
ii libc6-i386 2.11.2-5 Embedded GNU C Library: 32-bit shared libraries for AMD64
rc libwine-unstable 1.1.32-1+b1 Windows API implementation - library
ii linux-base 2.6.32-21 Linux image base package
ii linux-headers-2.6-amd64 2.6.32+28 Header files for Linux 2.6-amd64 (meta-package)
ii linux-headers-2.6.32-3-amd64 2.6.32-9 Header files for Linux 2.6.32-3-amd64
ii linux-headers-2.6.32-3-common 2.6.32-9 Common header files for Linux 2.6.32-3
ii linux-headers-2.6.32-4-amd64 2.6.32-11 Header files for Linux 2.6.32-4-amd64
ii linux-headers-2.6.32-4-common 2.6.32-11 Common header files for Linux 2.6.32-4
ii linux-headers-2.6.32-5-amd64 2.6.32-21 Header files for Linux 2.6.32-5-amd64
ii linux-headers-2.6.32-5-common 2.6.32-21 Common header files for Linux 2.6.32-5
ii linux-headers-2.6.32-trunk-amd64 2.6.32-5 Header files for Linux 2.6.32-trunk-amd64
ii linux-headers-2.6.32-trunk-common 2.6.32-5 Common header files for Linux 2.6.32-trunk
ii linux-image-2.6.32-5-amd64 2.6.32-21 Linux 2.6.32 for 64-bit PCs
ii linux-kbuild-2.6.32 2.6.32-1 Kbuild infrastructure for Linux 2.6.32
ii linux-libc-dev 2.6.32-21 Linux support headers for userspace development
ii linux-source-2.6.32 2.6.32-21 Linux kernel source for version 2.6.32 with Debian patches
ii login 1:4.1.4.2+svn3283-1 system login tools
ii passwd 1:4.1.4.2+svn3283-1 change and administer password and group data
ii x-ttcidfont-conf 32 TrueType and CID fonts configuration for X
rc xmp 3.2.0-0.1 A module player supporting AWE32, GUS, and software-mixing
ii xserver-xorg-video-nouveau 1:0.0.15+git20100329+7858345-4 X.Org X server -- Nouveau display driver (experimental)
