Font ISOCP.shx compatibility
When I try to open an Autocad dwg file with the ISOCP.SHX font, IntelliCAD substitute it with the txt.shx one. I've just copied the shx in the font folder. Is there any way to solve it?
  • edit the fontmap.you can try overriding the built in fontmap with you own. eg, start with an empty one.syntax for substitution line:font;substfont.shx
