Bricscad 10.6.6.1... same problem
I have already tested the new version of Bricscad and I have the same problem, switch between tabs files. You can see this behavior on video:
http://myfreefilehosting.com/f/a231976fef_5.72MB
Regards.
  • PC features:
    Core2 Du E7500, ATI EAH4350 1Gb, 4 Gb ram, Ubuntu 10.04, Catalyst 10.8, Bricscad 10.6.6.1
  • Updated Catalyst to version 10.9 it seems that problem has been solved.
    Regards
  • just disable desktop effects eg compis
    compiz is quite unstable, it delivers a large number of problems. Why you enable it in your working station?
