Snap to block entities
I can't snap to entities which are part of a block. The only snap mode available is "INSERTION" of the block. Is this normal? Hope not as it would be a big problem in usability.Reagards.Vaclav
  • I have had the same problem some times.In some cases close the drawing and open it again will do the trick, else bring in the blocks again (overwrite "yes").Easiest is to open a clean drawing and Edit/Copy everything from the old to the new and your OK.Maybe someone could tell us if there is some systemvariable that sets snapping to blocks.I haven´t found it anywhere
  • I have the same problem and I think that is a bug. Sometimes after a while drawing the osnap functions with blocks stop to work, and I have to close the drawing and open it again to have osnap working.
  • I am having this trouble occasionally in 4.1.0040. Flyover snaps work after ordinary snaps expire, but they sometimes stop working on blocks. I had one yesterday which would not snap to blocks again until I rebooted - opening and closing the file was not enough.
