UCS implementation
Suppose the following:1. Have a text entity with a rotation of 30 degrees in global UCS. Make the global UCS current.2. Double click on the text to see entity properties - you get "30 degrees" in the Rotation edit box as expected.3. Now change the UCS to the text entity's local UCS (UCS/Entity). LIST command gives correct result for the text - rotation is 0(ZERO).4. BUT: double clich the text again to see the entity properties - there's still "30 degrees" rotation - should/could it be also 0(ZERO)?I checked the behaviour of ACAD 2K with very similar results. It would be useful to have the entity properties dialog show data according to the current UCS so that user can modify them with respect to the current UCS.What are your opinions?ReagardsVaclav
