Conversion of a dwg towards a file images (.png)
Hello,
Thank you in advance
To my knowledge there is no direct way to create a png-file. Depending on what you want to use the png for, you could try one of these options:
1.
Export the dwg to a bmp-file. Open that file in your favourite image editing software and save as png.2.
Take a screenshot (Ctrl+PrtSc) paste this in your image editing software and save as png.3.
First export the drawing to pdf. Take a screenshot from the pdf in your pdf-reader and proceed as option 2.0 -
I'm sure that pdfcreator's printer driver allows you to print to png amongst many other formats
I use DocuPrinter to plot to png format.
