"copy properies" command
I search the "copy properies" command or button like on autocad ?
An idea ?
Thanks
if you mean match properties, you can type MA at the command line. I'm not sure what toolbar its on : )
Dan
Standard windows paintbrush like all other windows programs.
"copy properties" is "match properties" and is not listed in any menu bar, but you can set an alias for this command at the command alias editor that is in the Tools menu/custom section
The alias exists as MA and it's on the "Standard" Toolbar.
