Print problem
Good evening to all.
In the last two releases I have noticed a problem in print. When you select the area to be printed with coordinates x: 0.00 y: 0.00 in print the left part of the picture is not displayed for a few cm. I do not know if it's a real bug or just a configuration issue with the press. I hope someone melts my doubt.
In addition it is still possible to edit the properties of the selected printer that will not get you can choose to print with the memory of compuetr and not with the printer's memory.This would be very useful for large files because you can not print. In the version for windows is possible. We should add this functionality to the version for Bricscad. Can anyone confirm this?
Good luck to the developers.
CielitoLindo
