10.5.6.1 crashes when starting
Hi, I tried to set a user-profile located on a server as the active userprofile.
Now when I start Bricscad, it crashes during/after starting.
Here's the crash report:
--------------- 07-10-2010 09:45:39 --------------- v10.5.6.19874 ---------------
Unhandled Exception:
ACCESS_VIOLATION (C0000005) in module bricscad.exe at 001B:00000000
Registers:
EAX=00000000 EBX=00000006 ECX=0C804428 EDX=00000001 ESI=00000005 EDI=01B9AA54 EBP=0C6DBC90 ESP=0CD5FD10 EIP=00000000 FLG=00010246 CS=001B DS=0023 SS=0023 ES=0023 FS=003B GS=0000
Call stack:
, (0x0C6DBC90 0x00000001 0x0CD5FD94 0x01B9AA48), bricscad.exe, 001B:00000000
OdEdUIContextManager::operator=()+5262 byte(s), (0x00000000 0x00000000 0x0C6EF324 0x0000001D), cadapp.dll, 001B:00D5C5DE
Any ideas? I'd like to set the default profile active again, but can't becaus of the crash.
A reinstall did not work.
thx in advance
Martin
Perhaps open up the system registry and change the key HKEY_CURRENT_USER\Software\Bricsys\Bricscad\V10\en_US\Profiles\Default from what ever it is currently called back to "Default". (Don't include the quotation marks). Alternately open up the profile manager from the program menu and set the active profile directly (if you haven't already).
Thanks, got it fixed. FYI, i tried to load a drx at startup which caused the crash.
Everythings working now.
