Issues in Archlinux 64
Hello,
I've succeded to install bricscad on Archlinux 64
But I get this errors when running :
(bricscad:24734): Gtk-WARNING **: Impossible de trouver le moteur de thème dans module_path : « mist »
When bricscad is running, it doesn't show the model/layout tabs. I try to click on the location of the tabs, and it kicks me out of the program with this error :
(bricscad:25259): Gdk-CRITICAL **: IA__gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
terminate called after throwing an instance of 'std::out_of_range'
what(): vector::_M_range_check
Abandon
Do you have a clue ?
Thank you
Had same problem, as I think after todays update
Try to downgrade your gtk2 package. with version 2.20 works as it should
