How can I get a string from clipboard?
I want to draw a line starting at coordinates coming from the clipboard. (The clipboard content is "123,456" and the line should start there.)
I have been experimenting a litle bit with DIESEL and with AutoLisp, but did not find a solution.
Markus
Perhaps I'm missing something in your question but it sounds like a simple copy paste command? I regularly "copy" the display of my linux desktop calculator with eiter the "edit/copy" command or " ctrl c" to get the display to the clipboard...thne in Bricscad when line command asks for start point use the past from clipcoard or "ctrl v" to insert coordinate.
I should have noted I want to do this with a simple click on a toolbox button. So I have to assign some commands or a lisp function to a button.
I have not found any command to copy a string to the command line like Ctrl-V does (when focus is on the command line).
Markus
1. select some text with mouse
2. paste it anywhere with mouse middle button click, works with bcad command line as well
Hi - I also cannot paste anything from my clipboard into Bricscad. Both <ctrl>V and the menus choices give the same error: "unable to read clipboard data."
I can copy text from the clipboard into a drawing through "mtext."
I'm using OpenSuse 11.3 and KDE 4.4.4 - I think the difference in the flavors of Linux we're using makes a difference and we should report that. For example, maybe copy/paste works perfectly with Bricscad in Ubuntu or the whole GNOME world, but not in the KDE world or maybe just not with OpenSuse regardless of the desktop environment.
Works OK in opensuse 11.1/KDE3.5. It may not be the case but, using ksnapshot ang gimp, I noticed that pasting from clipboard only work while ksnapshot is open.
Interesting points above, but only loosely related to my problem.
I am looking for a command or function to insert a string from the clipboard to the command line so it will be part of a command sequence (line 123,456 ...) with 123,456 coming from the clipboard.
The clipboard related commands I have found only deal with inserting something into the drawing.
What Matthias wrote (#4) is what I am doing now. I am looking for a way to abbreviate that.
