SDS on Bricscad
in Linux
I gather from the documentation that Bricscad on Linux supports SDS.
I have not sorted out the Bricscad install folders. Where is the api folder which the header and lib file for SDS should be in. Can you give any recommendation concerning compiler? I am guessing Visual Studio 2005 suggested in the documentation is not appropriate. Can I use KDeveloper with GCC?
(Yes, I know SDS is depreciated etc, but I want to look at C/C++ add-ons and brx is not available on Linux yet!!)
Thanks,
Hugh
Hugh,
Did you ever sort this out? I am looking for the same header and lib files. Also, if you did find them, did you have any luck testing things?
Dan
