Prompt menu placement
Hi all
I have a problem : Under settings > program options > display > prompt menu you can choose if you want the prompt menu to appear, and if you want it, where you want it to appear. I find it very convenient, I want it, and I want it in the lower right corner. But the setting seems not to have the desired effect as the prompt menu always shows up in the middle of screen, where it is more a distraction than a convenience. Strangely, prompt menues from "getkword" out of my LISP-routines always appear in the lower right corner of the screen. Is anyone else having the same issues ?
