Recognizing a Group object trough VBA
I have created a Group object from polyline and circles. I would like to let user select an object and test if his selection is a Group object. I have tried the following:
Dim Obj As AcadEntity
ThisDrawing.Utility.GetEntity Obj, pt, "select entity...."
If TypeOf Obj Is AcadGroup Then
MsgBox "The object is a Group object."
Else
MsgBox "The object is not a Group object."
End If
For some reason 'TypeOf' does not recognize it. I have tested the same code on circle and polyline and it worked as expected.
Please advise, I must be missing something.
I am running Bricscad version 8.
Many thanks
Jiri
I could be wrong, but I don't think this is exposed in VBA... you can do this in lisp by searching the object's DXF entry I.e
(vla-get-Name (vlax-ename->vla-object (cdr (assoc 330 (entget (car (entsel)))))))
Maybe a little better:
(vla-get-objectname (vlax-ename->vla-object (cdr (assoc 330 (entget (car (entsel))))))) => "AcDbGroup"0 -
Function IsGrouped(ByVal ent As AcadEntity, ByRef group As AcadGroup) As Boolean
Dim result As Boolean = False
For Each Gp As AcadGroup In cadApp.ActiveDocument.Groups
For i As Integer = 0 To Gp.Count - 1
Dim e As AcadEntity = Gp.Item(i)
If e.Handle = ent.Handle Then
result = True
group = Gp
Return result
End If
Next
Next
Return result
End FunctionThis is vb.net code but you get the idea. Maybe inefficient but you can do it...
Damian, you rock!
ok, guys
many thanks for quick response. I have not tried your LISP stuff yet but what Damian is suggesting works very well. Many thanks again!
I made small modifications to accomodate to VBA:
Function IsGrouped(ByVal obj As AcadEntity) As Boolean
Dim i As Integer
Dim Gp As AcadGroup
result = False
For Each Gp In ThisDrawing.Database.Groups
For i = 0 To Gp.count - 1
Dim e As AcadEntity
Set e = Gp.Item(i)
If e.Handle = obj.Handle Then
result = True
IsGrouped = result
End If
Next
Next
IsGrouped = result
End Functionwhere obj is from
ThisDrawing.Utility.GetEntity obj, pt, "select entity...."
Many thanks again
Jiri
