VB SelectByPolygon
I want to find the Texts inside a polygon within a VB program. To do this I use the funcion SelectByPolygon but it does not work, I use it giving the array of points of the polygon and it does not return any objects in the selection.
Any clues? Is there an alternative?
Thank you
Guillerme.
Sub Test_SelectByPolygon()
Dim PtList(0 To 11) As Double
PtList(0) = 95.7475: PtList(1) = 95.7475: PtList(2) = 0
PtList(3) = 125.384: PtList(4) = 196.021: PtList(5) = 0
PtList(6) = 211.946: PtList(7) = 158.689: PtList(8) = 0
PtList(9) = 189.508: PtList(10) = 74.9487: PtList(11) = 0
Dim ss As AcadSelectionSet
Set ss = ThisDrawing.ActiveSelectionSet
Call ss.SelectByPolygon(acSelectionSetWindowPolygon, PtList)
ss.Highlight True
MsgBox "ss contains " & ss.Count & " entities"
ss.Highlight False
End Sub0 -
Thank you Ferdinand for your quick answer.
The function worked properly, my problem was that my drawing had a UCS coordinates. The coordinates that define my selection polygon come from an existing polyline, when I retrieve the points from the polyline I get WCS coordinates and I used this to define the polygon on the function and this function expects UCS coordinates so the polygon was in other area.
Thank you
Guillerme.
