Lines, objects recently drawn dissapearing
When i draw lines, it dissapears from window til i enter another command or 2 commands, even forces me to make a regen. Is it a problem of video memory?
V11.1.7 contains a fix for an issue that sounds similar, but it only occurred when using multiple model space viewports. Perhaps this is how your work?
Please check with V11.1.7, if the problem persists please file a support request.
Well, i think using multiple model space viewports is common for everyone of us working as drafters, designers, engineers, etc. I mean, if you're working with 3d drawings it's common to use more than one viewport. I guess it's a problem related to multiple paper space viewports, or at least where it happened to me the first time (and still keep doing so).
We failed to reproduce the issue you describe using V11.1.7. From your reply it is not clear which version you are using (it can be verified under Help... About Bricscad). Please file a support request and add a detailed description of what our support analysts should do to reproduce the issue, we will be glad to investigate and solve the issue for you.
For your information: Bricsys provides support from day 1, that is, from the day you start evaluating Bricscad.
