dynamic blocks
Hi there
I cannot find any help how to create dynamic blocks.
Can anybody help?
Thank you
Jan
From feature list: "You can insert dynamic blocks from your existing dynamic block libraries and adjust the custom properties and constraints in the Properties Bar."
You can insert and use existing DB, but no create or edit yet. But I hope it will be possible soon...
I see
I hope so too
Thanks
Does the new v11 allow to create and edit dynamic blocks?
If you mean v11.1.11-1, answer is no.
