V11 lagging scroll zoom
Hello! We bought few Bricscad V11 licences and I am suffering from weird lag. When I zoom out fast with scroll button and instantly zoom in again my view laggs significantly. I assume problem is somewhere in my settings but I have been using bricscad since 9 with same pc (windows 7 64bit, 4gb RAM, Intel i5 2,67Ghz, Matrox P690 PCIe X16). This zoomin/out lag occurs only with plans which include much data so I assume some kind of memoryprocessing is delaying my zoom. If I change to V10 and try same plan it works without this lag, I installed V11 and let it copy my settingst from V10. Lag is so rought that makes drawing with V11 almost impossible. Thank you if anyone have any good tips !
  • Are you using latest v11.1.11-1? I have same problem, but this release revert v11 to "normal" v10 speed.
  • Thanks! I will try that verion. I downloaded my version last monday, so I think I just missed the newest version. Lets hope that new version fixes my problem.
  • Problem solved! Thank you very much!
