on_start.lsp doesn't work
What version are you using? I have installed version 11 and everything works fine.
Yes, we solved some problems with startup Lisp files and (command)
sequences inside ... nevetherless, there are some problems pending, which
we currently solve with priority.
Beside that, there is a significant difference with on_start.lsp and on_doc_load.lsp :
on_start.lsp is loaded in initial drawing only, and only if 'AcadLspAsDoc'
system variable is On/1, then it is also loaded into any further drawing.
Many greetings0
