Pick Box Question
Is there a way to change the color and/or boldness of the pick box (I know how to change the size)? It get a bit hard to see with older eyes.
For V10 : Settings > Program options > Display . At the bottom there you can adjust the snap marker settings as you like.
That adjusts the snap box. I'm trying to adjust the pick box. As far as I can tell It should be under "selection", where you adjust the pick box size.
Maybe something to consider on future releases.???
