Properties PU
For some reason my Properties Pop-up isn't functioning-doesn't present on the desktop when an item is "double-clicked" or from the "right click" menu. I have it activated along with the Comman and Status bars both of which function properly. All other menus/pop-ups appear to be functioning properly.
  • I should mention this ion the latest V11.1.11 build. V10 still works fine.
  • Issue solved....It would appear it had to do with a dual screen mode function. When I open end V11 while V10 was up and in dual screen mode (on monitor 2) I openend V11 on the laptop screen and I got the V11 Properties Pop-up on the V10 desktop! I moved the V11 Properties Box back into V11 on the laptop screen (No.1) and all appears to be working properly. My apologies for the confusion.
