blocks and ucs
when I work on a different ucs other than the "world" , all the blocks I insert come aligned to the "world" ucs although I call the drawing at 0degree rotation angle. I want the block to be aligned to the current ucs unless I assign a rotation degree. How can this be made?Thank you all
