temporary files extension
I need to know what is the extension of the temporary files Bcad uses in the autosave. The reason is because i was working on a drawing and the program crashed with no option to save the file. So i can't recover from Bcad, but i can recover from the temp file.
  • Using:
    Menu > Settings > Settings... > In the input field type: save file path
    You can find the location of the temp files.
    Look for files with the extension SV$. Just rename to dwg.
    You may also want to adjust the: save time interval.
  • Thanks, i did know that extension from working with Acad, i didn't know Bcad also uses it. I have set save time interval to 30 min, it's a good interval since i'm working with heavy files (2mb min) and always w/ a bunch of files opened.
