refedit and drawing order
About refediting. Will the draw order sustain when close and save with the new version (V11)? With V10 it did not, and thereby renders the refedit feature not useful for me.
There's a paragraph about refediting on the new features page of V11. I wonder if the draw order has fixed. The refedit seems very useful to me. But a correct working draw order is paramount.
R.H. Jutten
Koopmans Bouw BV
the Netherlands
No. In v11, this still not work ;(
I make RequestID:22371, Entry date: 2009-12-17, Status: Fix Scheduled. But...
When I need fix something I choose 2 way:
1/ Go to computer with AC - if is this block complicated or dynamic.
2/ If it's simple block, I copy entities which must be above, copy it with distance ie. on left + 100, then select and delete source enetities and copied entied move back ie. right -100
