ucs and hatch
when I work in a ucs other than "world" all the hatch come at an angle aligned to the "world" one. same thing is through for blocks too. is there a solution? is there a patch if this is a bug?please help asap.
  • Use the hatch dialog (center tab) to set scale and angle.
  • what you say can be a possible solution but I believe that this is a big bug with the program. when we insert a block it must come aligned to the current ucs we are working on. otherwise it is no use to use ucs. and it is hard to calculate te angel all the time. I wonder if there is apatch for this bug.
  • It is a bug.I queued it for fixing. regards, sander
