Bricscad v11 für Windows
Hallo, wie kann ich ein pdf-Datei mit Layerstruktur erstellen? evtl. mit Acrobat 9 Pro?
  • If by layer structure you mean a list of layer names you may find this lisp useful. It prints the layer names to the text screen and also creates a text file that you can print to pdf.
    (defun GetAllNamesInTable (table / ent lst)
    (setq ent (tblnext table 'T))
    (while ent
    (setq lst (cons (cdr (assoc 2 ent)) lst))
    (setq ent (tblnext table))
    (reverse lst)
    (defun c:LiLa () (c:ListLayers))
    (defun c:ListLayers ( / lst file)
    (setq lst
    (cons
    (strcat "Layers in drawing " (getvar 'dwgprefix) (getvar 'dwgname))
    (vl-sort (GetAllNamesInTable "layer") '<)
    (textscr)
    (mapcar
    '(lambda (a) (princ "\n") (princ a))
    lst
    (setq file (open (strcat (getvar 'dwgprefix) "Layers in drawing " (getvar 'dwgname) ".txt") "w"))
    (mapcar
    '(lambda (a) (write-line a file))
    lst
    (close file)
    (princ)
    (princ "\nCommand: ListLayers or LiLa ")
    (princ)
