User Profile Manager
Good day,
I've set up my Bricscad Pro 11 with specific colors, texts styles, dimension properties, etc. My text height will not change, as well as my donut dimensions. I can change it, but when I close BC and open it again, the values are as before. How can I make sure that they stay changed?
Only settings that are saved in the registry are saved in a User Profile. Please check the Settings dialog to find out where a setting is saved: Drawing, Registry or Not Saved.
For all non-Registry settings, the usual way is to either
- modify an existing template drawing (under .\Templates folder)
- or to create your own template (can be a copy of provided template files)
file, and adjust all settings which are stroed inside the (template-)drawing0
