autocad .pc3 support / .PLT file
hi,
I'm looking from some information about printing with a virtual printer (making .PLT files). I've a .PC3 file from Autocad but it does'nt run on Bricscad. I'm running on ubuntu 10.04 64 bits and does'nt know how to install a virtual printer (like f.i. HP Designjet 650 C plus) to make .PLT files.
Does anyone have an idea?
Thanks
  • Hello, mine is not good in English, sorry. I use under ubuntu 10.04 the program "INKSCAPE" to making of from .plt files. You must generate a .pdf file in Bricscad or about your PDF plotter unjd then this in INKSCAPE as .plt print out.
     the best greetings from Saxony, thoralf
