PDF attach not work
Hi!!
I have briscad V11. When I try to attach PDF is an error
: _pdfattach
Error loading module for pdf underlay support.
My operating system is linux opensuse 11.3 64 bits.
Thank You
  • PDF Underlay does not work on linux yet.  It is listed in our comparison chart:
    http://www.bricsys.com/en_INTL/bricscad/comparison.jsp
  • Version 17.1.22 (x64) Revision 48146 on Ubuntu Linux 17.04 (64 Bit:)
    On my desktop PC the _pdfattach command works (although pathnames must restrict to ASCII(!) characters.
    On my notebook (same versions of BricsCAD and Linux) I get the message Luis Cagliari quotes (in German: "Fehler beim Laden des Moduls für Pdf Unterlagen Unterstützung".
    How can I fix the import on the notebook? Which error occurs when the module is going to be loaded?
    Regards
