Bricscad 11 crashes with ubuntu 10.10
When drawing is loaded, when I draw a horizontal line 1 unit long, and after a vertical 2 units long bricscad exits.
Joao, is that happening only with the 'dynamic mode' turned on? It does the same for me.
(bricscad:6854): Gdk-CRITICAL **: IA__gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
Segmentation fault0 -
Similar situation here using Mandriva 2010.0 Powerpack 64bit
(bricscad:2475): Gdk-CRITICAL **: gdk_drawable_get_depth: assertion `GDK_IS_DRAWABLE (drawable)' failed
DWGdirect warning: priority={0} Substituting font "txt" by default font.
Mandriva 2010 Powerpack 64bit.
Ok, this seems to work so far -
type os
in the search bar next to binoculars type dynamic > then enter
Turn off - dynamic input at pointer
Turn off - editable dynamic dimensions
Continue drafting.
Thank you Brian, it seems to be working fine. But I'll have to try it a bit longer to confirm. I will post the result later.
Ubuntu 10.10 32bit - Sony Vaio VGN-FW51JF
"Turn off - dynamic input at pointer
Turn off - editable dynamic dimensions"
Doesn't work for me. It still crashes the program and closes it immediately.
Still working fine after "Turn off - dynamic input at pointer and Turn off - editable dynamic dimensions". I will be waiting for the patch because the dynamic input function seems very interesting.
Ubuntu 10.10 Bricscad 11, Sony Vaio
