dwg to pdf
Hi all, I do not understand how to preview an A1 Pd and modify the layout to A1 . In autocad, I would right click on a layout tab, go to page setup manager ,modify , select dwg to Pdf in the printer option, change to A1, and preview the layout which is now A1. How do I do this in briscad. Can anyone assist. This is the only thing I have found that is very diferent from autocad.
cheers
Hi Stephen,
Click the layout tab that you want to plot, then go to page setup. Select the printer or pc3 file, change the paper size and hit Preview. Cheers, Damian
