unable to run on debian squeeze - BricscadClassic-V11.1.16-1-cs_CZ
i got this message : /opt/bricsys/bricscad/v11/bricscad: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
but the libary is installed
~$ ls /usr/lib/libz*
/usr/lib/libz.so.1 /usr/lib/libz.so.1.2.3.4
Do you use a 64bit system? In that case, you need to install the "ia32-libs" package.
If that does not help, you can use "ldd" to see where the library loader looks for the shared libraries.
cd /opt/bricsys/bricscad/v11/
LD_LIBRARY_PATH=. ldd -r bricscad0 -
Yes I have 64bit system and Im missing the "ia32-libs" package. So this is probably the problem, but I do not realy want to mess the system with 32 libs only because of trying briscad ...
Is there any chnce thet the 64bit version is realised?
Thank you
You shouldn't consider it being a mess, since package manager handles it for you, and no cruft will be left over, when you decide to remove the package.
I installed the ia32-libs package and now it complains about : bricscad
/opt/bricsys/bricscad/v11/bricscad: error while loading shared libraries: libexpat.so.1: cannot open shared object file: No such file or directory0
