Importing TT fonts
I experienced severe problems when trying to import text styles, which use a TT font, from one drawing into another. IntelliCAD crashes when such text styles are copied. When a dwg is inserted as a block or when an Xref is binded, IntelliCAD crashes when you try to launch the IntelliCAD Explorer, if this block or XRef contains TT font styles. As long as you don't open the explorer, you can keep working in the drawing. You can even edit the text styles or add new ones, using the STYLE command.Therefore, for the time being, it is better to make sure that all blocks or dwg's that you want to import do not contain any TT font styles.
