Error - Buffer Overrun
PASTE CODE HERE
I created a new drawing by saving changes to a client's drawing and have opened and closed it numerous times since then.  Today I tried to open it and got the following message:
Error - Buffer Overrun     This File may be an Auto CAD R14 Beta Format File
Followed  by:
Warning: Error was found during open. We recommend that you close this drawing and run DDREVOVER on this one.
When I go to file and run Recover I get a message saying "Could not rename 'Path\Filename.dwg' to 'Path\Filename.bak' File 'Path\Filename.bak' already exists or could not be created (invalid path)
Please help.
  • Scott,
      I get the "buffer overrun" error occasionally with Intellicad files. I don't know about your path issue, but I can usually fix the file by using Autodesk's DWG Trueview (it's a free download ifyou don't already have it) and converting the problem file to some earlier version like 2000 or R14. Hope this helps.
  • Or use the new TeighaFileConverter from the ODA, it has an audit feature.
    Dan
  • This is a v7 type error. V7 is based on the old style opendwg libraries. You could try a trial download of the current version, it's valid for a month, and run recover with it.
