Shortcutmenu woes in V11
Correct me if I'm wrong but if shortcutmenu is set to (0) then isn't "right clicking" supposed to repeat the last command like the spacebar or enter? For me, regardless what command was used previously it keeps calling up the erase command. What gives?
This problem was reported before:
http://www.bricsys.nl/common/support/forumthread.jsp?id=12978
No solution though (apart from restarting).0 -
BTW: I cannot reproduce this problem.
Restarting corrects the issue. Is really a bug and should I issue a support request?
I would.0
