Slow with big files
Hello
Here are my specs :
Intel Core2duo 2ghz
4gb ram
nvidia geforce 8800 gts 640mb
OS : Archlinux + vmware for windows XP
I'm currently working with dwg files which contain an entire city (75mbytes)
I want to move from Autocad 2008 which I use under vmware to bricscad v11
But when I tried to open the file, everything is painfully slow.
There are no problems with small files, but when it gets big it's impossible to work
I checked the opengl capabilites of bricscad, but nothing changes...
Is there some release date when Bricscad will reach Autocad 2008's performance level ?
Or is it a problem which can be solved now ?
Thank you !
I've seen this happen when the dwg has many solid/gradient fills. If your files don't have them, what size do you consider "big"?
In my system (Athon X2) Bricscad feels as fast as AutoCAD in a VM.
When I get rid of fills it's faster, but it's still more than 50% slower than autocad in VM which runs very smooth, it's a 75mbytes file, a city of almost 70km/70km 2 layers with buildings and roads, when I zoom very close it gets faster, but when I unzoom it gets 10 seconds between my mouse gesture and the response...
Why would fills cause such problems ?
Core2Duo 3.8 Ghz (acceleration)
8gb ram
nvidia 9600GT
openSUSE 11.3 x86-64
solid/gradient fills - miss
dwg file 15 Mb
zoom too slowly
