Unwanted Auto-zooming
For some reason BCad has started automatically zooming the scale of an unclocked paperspace viewport every time I double-click inside to fit the entire model space drawing inside the viewport. This used to only happen when a paperspace viewport was first created. Has a setting become changed that I need to change back, or is this a major bug at a recent release?
Jamie
  • I'm using Bricscad Pro 11.2.5 & I can't get mine to do what you're saying. Mine behaves normally with an unlocked viewport. That said, however, I always lock my paperspace views once I've got the parameters set the way I want. It appears you've got something else going on other than a Bricscad quirk. Good Luck.
  • Hi. Can anyone from BCad advise if there is a support request open for this kind of issue? If not I'll file one. Thanks.
    PS. Could a changeable setting cause this kind of behaviour? I'd assume not as I can't think it would ever be wanted behaviour.
  • Hello Jamie,
    our user forums are meant for communication with other _users_. For questions or bug reports, please submit a support request (as mentioned in the yellow frame on the page where forum messages can be posted...)
    This is not to annoy our users, but on the contrary, to ensure that our analysts and developers can provide you faster responses. E.g. if 10 analysts would read and investigate all forum messages in parallel, then they would handle 10 times less questions than when the questions would come in as support requests and be dispatched one question to one analyst each.
    Please file a support request, it is the most efficient way to communicate with Bricsys development. Thanks for your understanding!
