Raster Image, cals
Hello!
Our company uppgraded from v.6.2 to 11.1.15.
In the "old" version we opened drawing with att. cals (CALS type 1 (*.cal)).
They won't open in new version...
Any solution?
Cheers
Jörgen B. /Sweden
  • This image format is not availble in any of the recent versions.  I occasionally receive image attachments in this format from electrical companies as I assume this is how they archive their old hand drafted drawings.  From memory I converted them to TIF or JPEG using Irfanview. The little bit of research I did showed the file format to be relatively simple so there may be a way to automate this but the chances of it becoming native in BCad are probably based on user need.  It is worth filing a support request to check out the likelihood though.
