is it possible to convert Esri shapefiles into CADD .dwg files within Bricscad?
Try this add-on: http://www.bricscad.com/common/applications/application.jsp?app=276
Hi Michael,
I have tried the SYCODE plugin and it works well for importing the geometry from SHP, but it does not handle attributes. They are not imported into the DWG. Also, there is no SHP Export from Bricscad that I have found yet and am still interested on these two items viz.
- attributes import from SHP into Bricscad
- SHP export from Bricscad, including attributes.Any experiences out there would be nice to hear.
Regards
Rakesh Rao
www.coordsys.com0
