TEXT MASK
Can anyone help with masking single line text in Bricscad. IN Autocad it is simple - command textmask. I have been able to mask MTEXT but not single line text
  • Hi Terry,
    You can use the WIPEOUT command in Bricscad and create a mask over any object, text included. That should solve your problem. Even in AutoCAD, the TEXTMASK command uses WIPEOPUT objects. We have automated this process a bit in our GeoTools productivity application by creating a command called GT_ENCLOSE which can be used to enclose text/mtext objects with WIPEOUT, 3dface, solid or circle objects.
    Regards
    Rakesh Rao
    Blog: http://rakeshrao.typepad.com
